When to cut down trees.
   / When to cut down trees. #1
JDRandyC
Isn't there a time of the year when you can cut down trees and not have them try to re- sprout later?
   / When to cut down trees. #2
I am not sure about the re-sprouting issue but I like to harvest trees in the late fall early winter when the leaves are off as there is less mess to cleanup.
   / When to cut down trees. #3
I'd probably say late fall/winter, assuming you are in a location with strong seasonal variations, since that gives you the most delay before the spring/summer growth season hits. In general, fall/winter is a good time for other reasons, as the sap is down and the leaves are off. But to be honest, I have seen all sorts of trees eventually sprout suckers, regardless of when cut. It probably depends on the species and other factors.
   / When to cut down trees. #4
It must not be late July-early August because the stumps sprouted like crazy the following spring in my field clearing project.
   / When to cut down trees. #5
Suckers sprouting from cut trunks is a survival adaptation of North American trees due to beaver depredation; and probably only arose in the past 10 to 15,000 years.
Most trees from other continents, especially South America, don't have that adaptation; which is why when American beavers were transplanted in South America, they devastated riparian forests.
   / When to cut down trees. #6
That's fascinating. I never really thought about it and would never have guessed that it's a regional adaptation.
Personally, I like to cut in the Winter, if I can wait, being that I live in a strongly seasonal area.
No leaves - except the beeches and some of the more stubborn oaks - makes chipping much easier.
Easier skidding when the ground is frozen; less getting stuck.
Much less saw dulling grit in the bark if skidded out in the snow, even though I still bark with a spud before cutting for the splitter, if the bark will separate.
Much less damage to the soil structure & roots of neighboring trees when the ground is frozen.
   / When to cut down trees. #7
Not all trees regenerate if cut and "killed". If you have trees that are regenerating and you don't wish to have them do so,you have some options and I would present you with some options. You can grind the stump and major roots out. You can burn them. You can dig them out. The least invasive and least toxic method is to bore the stump as soon as you cut the tree.You can use the tip of your chain saw or big drill bits. Pour pure roundup in the holes. Leave it alone and that should do it. There are PLENTY of other chemicals you can use and they are generally not really necessary. Things like Garlon, 2,4,D, Crossbow,etc in pure form are pretty nasty. I have first hand experience doing this in coast range forests and urban locations.
   / When to cut down trees. #8
I've cut a lot of trees and the only way that works for me is to use Roundup (or generic glyphosate) concentrate on the freshly cut stump. Read the glyphosate/Roundup booklet on killing stumps enclosed with the product.
It says to cut the tree off near the base and then immediately paint the stump with the concentrate. I coat it within five minutes of cutting and then again a couple times within the first 10 or 15 minutes. I have never had one re-grow or get any suckers that way. It won't work if you wait too long.
After a couple years I can pop the stump out with a backhoe or just leave it flush with the ground to rot. No muss, no fuss.
   / When to cut down trees. #9
If the suckers come back up in spring just spray them with some brush killer. I got some fence line spray from my local farm store and it works great on suckers. Usually spray them twice and the tree is dead.
   / When to cut down trees. #10
Ditto what others have said in the fall after the leaves have fallen off, and on a calm day. Never liked to be falling trees with the wind blowing, regardless of how slight of a breeze.
Another trick I have used on tree stumps, don't tell the EPA police, is to use a three quarters inch wood bit and bore several deep holes in the top of the stump and then fill the holes with mutric acid, obtainable at Lowes. Check the holes every couple of days and replenish what the stump has absorbed. The old stump does not liking drinking the acid.
2015 Massey Ferguson GC1720 Tractor (A44391)
2015 Massey...
2015 Ford F-350 4x4 Utility Truck, VIN # 1FD8X3H67FEC72951 (A44391)
2015 Ford F-350...
EZ-GO Freedom RXl Golf Cart (A44502)
EZ-GO Freedom RXl...
Chery 9.5' 30 Drawer Workbench (Silver) (A44502)
Chery 9.5' 30...
2014 Ford Taurus AWD Sedan (A44572)
2014 Ford Taurus...
CAT IT28 Wheel Loader Pallet Forks (A44391)
CAT IT28 Wheel...
