When to cut down trees.
   / When to cut down trees. #11
I like winter. Less mud, no wasps, no leaves, no ticks, etc. My cut stumps sprout no matter when I cut them.
   / When to cut down trees. #12
Suckers sprouting from cut trunks is a survival adaptation of North American trees due to beaver depredation; and probably only arose in the past 10 to 15,000 years.
Most trees from other continents, especially South America, don't have that adaptation; which is why when American beavers were transplanted in South America, they devastated riparian forests.
Neat factoid.
   / When to cut down trees. #13
A little off topic, but if cutting for firewood, cut in the summer when in full leaf and let the tree lie there whole until fall / winter. The leaves will draw moisture out of the tree which, with no roots to replenish the water, speeds up the seasoning process.
   / When to cut down trees. #14
That's an interesting statement, any studies to back it up?
In http://arboretum.harvard.edu/wp-content/uploads/Botanical-Review-Sprouting-in-Temperate-Trees.pdf it's stated that
Sprouting is a universal attribute of angiosperm trees
Trees sprout in Europe, it's been a management practice since Neolithic times, but there they term it "coppicing".
From https://www.google.com/search?q=Coppicing&oq=Coppicing&aqs=chrome..69i57&sourceid=chrome&es_sm=93&ie=UTF-8
Coppicing is an English term for a traditional method of woodland management which takes advantage of the fact that many trees make new growth from the stump or roots if cut down. In a coppiced wood, young tree stems are repeatedly cut down to near ground level.
Coppicing is the process of cutting trees down, allowing the stumps to regenerate for a number of years (usually 7 - 25) and then harvesting the resulting stems.
It makes use of the natural regeneration properties of many tree species, including Oak, Hazel, Maple, Sweet Chestnut, Lime and Ash. Cut such trees down and they will regenerate from the cut stump, producing many new shoots, rather than a single main stem. Regrowth can be exceedingly rapid, with new shoots growing as much as 5cm a day. Oak stems can exceed 2m growth in one season, while Sallow may grow to almost 4m high in the first summer1. The word 'coppice' is derived from the French 'couper' which means 'to cut'. Coppice trees and their produce are known as 'underwood'.
from Coppicing
Trees sprout in Asia.
I know the "Tree of Heaven (Ailanthus altissima), from China, sprouts grow rapidly,
The tree of heaven is a very rapidly growing tree, possibly the fastest growing tree in North America.[37] Growth of one to two metres (3.3 to 6.6 ft) per year for the first four years is considered normal.
from Ailanthus altissima - Wikipedia, the free encyclopedia
   / When to cut down trees. #15
Isn't there a time of the year when you can cut down trees and not have them try to re- sprout later?
No.
The only way to stop a tree from growing back is to treat it with herbicide very soon after cutting it. And as always, read and follow the label before using any herbicide.
The exception to this rule is pine trees. There may be other exceptions too that I'm not aware of. Pine trees have their growing point at the top of the tree, and if you cut that off, they will not grow any more. Other trees have growing points throughout the tree, and will grow from any point.
   / When to cut down trees. #16
For a stump killer, I use Tordon RTU. It's around $15/qt., squirt around the new growth (outer edge) of the stump, 1 qt. will cover a bunch of stumps (depending on size).
   / When to cut down trees. #17
from Coppicing
I know the "Tree of Heaven (Ailanthus altissima), from China, sprouts grow rapidly, from Ailanthus altissima - Wikipedia, the free encyclopedia
There is a Eurasian beaver that is native to almost all of Europe and out into Siberia. They don't have quite the same lodge, pond, dam, feeding characteristics as the Canadian beaver.
   / When to cut down trees. #18
Not all trees regenerate if cut and "killed". If you have trees that are regenerating and you don't wish to have them do so,you have some options and I would present you with some options. You can grind the stump and major roots out. You can burn them. You can dig them out. The least invasive and least toxic method is to bore the stump as soon as you cut the tree.You can use the tip of your chain saw or big drill bits. Pour pure roundup in the holes. Leave it alone and that should do it. There are PLENTY of other chemicals you can use and they are generally not really necessary. Things like Garlon, 2,4,D, Crossbow,etc in pure form are pretty nasty. I have first hand experience doing this in coast range forests and urban locations.
Hey hey hey... You're saying the least toxic method of killing a tree is to "pour roundup in the holes" you bored. I'm gonna say that burning them out, grinding them out, or drilling holes, filling with corn and setting the hogs to them would all be less toxic. I'm sure your roundup method works, but don't go around thinking it's the least toxic way to do something.
John Deere Z994R (A60462)
John Deere Z994R...
iDrive TDS-2010H...
2008 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2008 Godwin...
2010 Volkswagen Routan Van (A59231)
2010 Volkswagen...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A56438)
Bulk Lot of over...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A60460)
2017 Chevrolet...
