When to use Stay Rods
   / When to use Stay Rods #1
8N_John
Kearney, Missouri
1952 Ford 8N
When is it appropriate to use Stay Rods (parts 4 and 5 on attachment)? Sounds like they are not intended for use when brushhogging, but maybe only when pulling a trailer? Any other uses for them?
   / When to use Stay Rods #2
John,
Yes they are really only used for fixed drawbar work like pulling a trailer or manure spreader or the like.They are intended to take the load off the lift arm bushings by transfering the load to the top link pin. They will also keep the drawbar at a fixed height. Do not use them for three point implements.
By the way, you might want to check out the N Board at ytmag.com .
Those guys have helped me out many times on my 2N ( 1947 ) .
By the way , if you are going to do any work with a bushog , get yourself an overrunning clutch ( ORC ) - about $ 50-60 at Tractor Supply . Since your 8N does not have live PTO , if you do not have an ORC , the momentum of the blades on the bushog will shove your tractor forward after you mash in the clutch. You can get a very nasty surprise like that .
Fortyseven2n
   / When to use Stay Rods #3
In addition, these stay rods also hold the arms fixed for using a one-way hyd. ram plumbed into a port on your hyd. system. Then the 'lift' control operates the ram rather than the 3pt arms (which are fixed and can't move). Real advanced and handy in their 'day'.
2022 DRAGON 130BBL VACUUM TRAILER (A53843)
2022 DRAGON 130BBL...
2005 CHEVROLET SILVERADO (A53843)
2005 CHEVROLET...
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A53473)
2019 Ford F550...
ASCO Transfer Switch (A52377)
ASCO Transfer...
ALUMINUM HEADACHE RACK (A53843)
ALUMINUM HEADACHE...
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53473)
2016 Ford F350 -...
