When to use WD hitch
   / When to use WD hitch #11
Wow - only 5000 lbs.?
Yup
I think you will find a lot of trucks that say to use a WD hitch at 5000 lbs, most people don稚 know it. It痴 one thing I miss about the 3/4 ton Chevy I traded in, it had a class V hitch and was something like 11,000 lbs.
My dually is rated for 12,000 lbs. The label on the factory hitch specifies WD over 5,000 lbs.
   / When to use WD hitch #12
We just got a new pop up trailer and pull it with a toyota sienna. This new trailer when fully loaded is at the max of the towing capacity of the van. On my truck the towing tables show at what weight to add a weight distribution hitch. The van just says max 3000lb. When the weather clears up I want to take it to a flat parking lot and measure how much sag the trailer causes and how much rise I need on the hitch to level it out. So how do you determine when just air bags or helper springs are needed versus a WD hitch?
I would also be concerned about the word 'max'. Just cause one can don't mean one should.
So please take into consideration load rating of tires are the P rated or load rate D or E?
Is the transmission a CVT? Are they known to have any normal issues that can be amplified by running a full towing capacity?
Do you have a local grain/feed store near you? Some of them have a free public scale which means you can pull up with your loaded trailer and find out what you're really dealing with. If you go to eTrailer or someone else looking into a WDH they want to know to the best of one's ability all the weight numbers to get the correct set up.
If you're OK with all that then by all means enjoy the camper!
on edit:
"So how do you determine when just air bags or helper springs are needed versus a WD hitch?"
air bags and spring helpers help with sag and may be great for pulling tractors, equipment etc. but a TT is a tad different.
You are pulling a box of sheeted plywood for a visual. the WDH helps move some of the weight to the front wheels which helps with loading the wheels for steering control.
The ball is a pivot point and the wind whips the trailer pretty hard versus equipment where the wind is not blocked like holding up a sheet of plywood.
So with towing at full max a WDH may be the best option to ensure the load is spread to the front wheels for steering control.
Hope I didn't confuse the both of us still on my second cup of coffee.:D
   / When to use WD hitch #13
You are kind of in a trick bag with the F-150 factory tow setup. You are good for 1000 lb tongue/10,000 towed, but only with WD, otherwise 500/5000. You can't just pull the factory hitch & replace it without serious work - the bumper mounts are different with the tow package & dependent on the OEM hitch. We have a 2008 crewcab F-150 w/factory tow package & I looked into it a few years back.
   / When to use WD hitch #14
My 3/4 ton Dodge I used to own also said anything over 500/5000 lbs I needed a weight distributing hitch.
   / When to use WD hitch #15
I just looked at a 1994 Chevy 3500 dually with a 454. Factory mounted receiver hitch was rated at (drumroll please........):
500# tongue weight and 5000# gross trailer weight unless using a WD hitch.
They make higher rated receivers that bolt right up of course, but I was pretty surprised to see it that way from the factory.
   / When to use WD hitch #16
A true class V hitch is rated much higher. You can tell its a class V partly because the shank that goes into the receiver is much bigger. My Chevy with the class V came with an adaptor so you could use the standard size shank also. Also the hitch and draw bar the ball goes on come in different quality and weight ability.
2014 MACK CHU613 FRAME (INOPERABLE) (A58214)
2014 MACK CHU613...
TANK MANIFOLD (A58214)
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
2007 Pierce Dash Pumper Fire Truck (A55973)
2007 Pierce Dash...
6' SCRAPE BLADE, 3PT (A52708)
6' SCRAPE BLADE...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
