countrybumpkin
Elite Member
- Joined
- Jun 14, 2005
- Messages
- 3,237
- Tractor
- Kioti, kubota
That’s not the correct valve , that’s a 120 volt coil and it’s not a tandem center style.
Thank you, I was actually looking at that exact valve and sub plate. My tractor flows 12.3 GPM so I ended up going with the D03. My main concern is that I am pretty limited on space because my tractor is so compact. That setup looks like the lines would be running side to side and the solenoids on the valve would be running up and down. I really wanted to find something where the lines run the same direction as the solenoids to fit in a tighter area.
That痴 not the correct valve , that痴 a 120 volt coil and it痴 not a tandem center style.
N2DFire,
Thank you that is a very nice write up. I didn't go with a full size grapple. I ended up going with a small stump grapple as I have quite a few trees to move. I will have to post pics along the way with my progress.
