Where do you store your attachments?
   / Where do you store your attachments? #1
NewfieDan
Eastern, NL
Kubota BX2360
When switching between implements(blade to FEL) where do you store the ones not in use?
On my 2360 I don't have the option to use both the loader and front blade at the same time, as an example. Either the loader arms or the front blade and sub-frame have to come off. Do you store them inside, an equipment barn or out in the elements?
   / Where do you store your attachments? #2
always a compromise as room is a premium. I store my rotational attachments under cover, either tarp or dry storage. My attachments that do not move via the PTO stay outside in the harshest of elements. So far so good.
   / Where do you store your attachments? #3
I keep all my toys on skids in the barn. Just wheel my choice to the tractor use the QH to mount and go.
   / Where do you store your attachments? #4
all of mine stay indoors in one of 2 separate sheds. ill not leave expensive implements out in the weather.
   / Where do you store your attachments? #5
I am fortunate to have room in my barn for all of mine. If I didn't, I would buy some kind of pre-fab shelter for implements-they last longer and look so much better when shedded.
Will
Sent from my iPhone using TractorByNet
   / Where do you store your attachments? #6
My tractor and implements are stored in a 24x36 metal building with a concrete floor. All implements are on stands with 5" swivel casters so they can be stored along the sides and rolled to the tractor as needed. Tractor and implements look like the day they were purchased and hook up is effortless.
   / Where do you store your attachments? #7
I store mine in a shed I built for the purpose eight or ten years ago:
It has a concrete floor, which works well with the dollies I made for each implement to make it easier to hook them up, and to let me squeeze more into the space:
Terry
   / Where do you store your attachments? #8
Don't have any place to put it so my stuff lives outside except for the hay equipment ($$$) and the bush hog ($) which lives indoors during the off season.
Just rented a farm with a couple equipment sheds, so that may change.
   / Where do you store your attachments? #9
Every single one of my attachments are stored outside, in the weather, all year long. Just like my tractor (although at times it's stored in my father's garage but it doesn't live there)
I'd love a barn for everything, it really would be nice.
   / Where do you store your attachments? #10
small stuff / electronic stuff in shed. rest outside on concrete. keep the stuff out of the mud and out of the weeds for quicker mowing / weed eating, and keeps from finding that un-friendly snake or critter under some decks / metal.
do not even bother with a tarp or anything for stuff outside. at most some rust, and need to hit some things with grease when it actually gets used, and the rust comes off within a few minutes of use on the blades/discs/cutting edges. no water pools on any of it. to much moisture a tarp can hold in, figure just better to let the stuff drip dry, and wind dry out faster.
tarps just tear up and make lots of noise, and gives rodents and other critters a spot to nest.
Willmar 4300 Wrangler Loader (A51039)
Willmar 4300...
Adams Conveyor (A51039)
Adams Conveyor...
2015 Ford F-550 4x4 Mason Dump Truck (A48081)
2015 Ford F-550...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2005 Ford F-250 4x4 Ext. Cab Pickup Truck (A48081)
2005 Ford F-250...
2005 OVERLAND TANK KILL TRAILER (A50854)
2005 OVERLAND TANK...
