Where is hydraulic fluid drain on TU205?
   / Where is hydraulic fluid drain on TU205? #1
terraformer
N.E. Mo
Mahindra 3510, Bolens G192/Iseki 1910
I would like to change the fluid. I can see the filler above the 3pt hitch and I think the dipstick is under the seat but can't identify the drain. I have a generic iseki manual but it isn't clear.
Thanks
   / Where is hydraulic fluid drain on TU205? #2
I have an older Iseki TX1500F and my dip stick is also under the seat and it you look straight down from there at the low point of the gear case there is a horizontal plug (bolt head). If you remove that it drains the gear case and hydraulic oil.
   / Where is hydraulic fluid drain on TU205? #3
Also check the low point at each rear axle. I am not sure which model , but one has gear reducers at the axle and a drain on each side.
2017 Chevrolet Ambulance (A55973)
2017 Chevrolet...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
Carry-On 6'x8' Trailer (A53316)
Carry-On 6'x8'...
MERCURY VERADO ENGINES (A55758)
MERCURY VERADO...
Kubota L3130 (A53317)
John Deere 7230 131HP 4WD Agricultural Utility Tractor (A56857)
John Deere 7230...
