</font><font color="blue" class="small">( ................ what do you think junkman /forums/images/graemlins/confused.gif )</font>
I think that I wish that I never went to this post!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif I have no idea what the original grease that was used by the spindle manufacturer was, but I know that it was green in color. I filled mine against my better advise with the grease that I had on hand. I had planned to remove the spindles last winter and clean the bearings and install new grease, but like most things, I never got around to it. I hope to do it this winter, but there is no guarantee. One problem that I see with grease, is that what you purchase today, might not be available next week. For this reason, I am going to purchase a case of 12 tubes to be used exclusively for the MMM. I see this starting to be the same as the discussion about Super UDT vs. UDT. Unfortunately there is a lot of opinions, (mine included) that have some validity, but much of this is only opinion. I know that machinery bearings are closely inspected for wear and are always properly lubricated with the correct lubricant for the type of bearing that is in use. I have also seen a very expensive bearing comparative to its size fail because of improper lubrication. It was a bearing inside another bearing and the total diameter was 3/4" and the cost for the bearing was $90. Today, that bearing is no longer available and proper maintenance it the only thing that will keep that machine working. I don't grease my pivot points as often as recommended, but I do watch bearings to make sure that they are properly lubricated. Even the wrong lubricant is better than no lubricant. When you consider the dynamics of the spindle spinning at 6000 RPM, you realize that lubrication is a must. Add to that the side thrust of the belt turning on a small segment of the belt pulley, and it increases the need for lubrication. A bearing that is left inactive for any length of time also has the grease harden and it looses its ability to perform properly. I have some NOS (new old stock) rear axle bearings for my 1964 Corvair that cannot be used until the old grease is totally cleaned out first. It has hardened to a brittle paste. These bearings haven't been available since the early 1980's and today sell for upward of $200 apiece. PM (preventive maintenance) is always less expensive than repairs, and Murphy's Law states that it will always fail when it is least convenient. I use the Law of Common Sense, if it seems reasonable, then it must be.... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
