Where to buy a ballast box
   / Where to buy a ballast box #1
bill177
Upstate New York
Massey Ferguson GC2300
I need a ballast box for my MF GC2300. I don't want to build one - no welder and no metal either. Need to put about 300+ lbs. on the rear. What I had was plywood and it gave out after several years use. Suggestions would be appreciated. Thanks.
   / Where to buy a ballast box #2
Try a Box blade, double duty.
Have one - but what I really need is a ballast box for this particular application. Thanks anyway - the reply is appreciated.
   / Where to buy a ballast box #4
You could make one out of concrete, buy one of the tractor supply 3pt drawbars, to get the pins and the start to bolt some angle iron to the predrilled holes in the drawbar, that come up to form your top link connection. The most metalworking you have to do is drill some holes in the angle iron, you can use a hand drill for that. Put everything in a box for to fill with concrete, when it sets up, remove the wooden forms and now you have a concrete weight with your 3pt connections cast into the concrete.
Not a lot of work, or money. I am not sure which of these bars you need. depending on your size. I would use some 2 inch angle for the uprights, and drill your holes and get the cross pin for the top link.
CountyLine® Cross Drawbar, Category 1, 3/4 in. dia. - Tractor Supply Online Store
CountyLine® Cross Drawbar, Category 0 with Category 1 Pins - Tractor Supply Online Store
James K0UA
   / Where to buy a ballast box #5
If you're into a do-it-yourself with no welder needed, build a box form with plywood/osb, stick a drawbar through it and bolt something to catch your top link with, and fill it with sack-crete. If you oil the wood down before placing the crete, you should be able to strip it right off after the mud cures. Concrete is generally in the 140 lb./cubic foot range to give you a reference for box size according to how much weight you need.
Sent from my LGL35G using TractorByNet
   / Where to buy a ballast box #6
James K0UA
Man that's really wierd we were thinking the same thing at the same time :)
   / Where to buy a ballast box #7
"great minds run in the same channel".. :)
James K0UA
   / Where to buy a ballast box #8
James K0UA
Use this for the toplink
EMP Tractor Draw Bar Stabilizer for Category 1 Tractors, Model# 7350-1 | 3-Point Drawbars Stabilizers| Northern Tool + Equipment
   / Where to buy a ballast box #9
   / Where to buy a ballast box #10
Well now, there you go, a complete solution, minus a little plywood or OSB, some used motor oil, a few bolts and nuts and 4 80 lb. bags of sackcrete. Heck it don't get a whole lot easier than that.
James K0UA
He can get busted bags at lowes for 1/2 off. Ask to look at their dunnage pile and get a sheet of OSB and he will have a inexpensive ballast.
2016 FREIGHTLINER M2 24FT TANDEM AXLE FLATBED (A43004)
2016 FREIGHTLINER...
2013 KOMATSU D39EX DOZER (A43003)
2013 KOMATSU D39EX...
2024 Ford F-650 Rollback Truck, VIN # 1FDWX6EC6RDF00029 (A44391)
2024 Ford F-650...
2018 Kubota L4060 Tractor (A44391)
2018 Kubota L4060...
2007 International 4400 Truck, VIN # 1HSMKAZN97H451429 (A44391)
2007 International...
2010 UTILITY 53X102 DRY VAN TRAILER (A43004)
2010 UTILITY...
