Oil & Fuel Where to buy Oil and Hydraulic Filters at a discount
   / Where to buy Oil and Hydraulic Filters at a discount #31
My father in law worked for coopers ( cheap aftermarket) filters in the uk for 25 years and he said when they came off the line they just applied manufacturers logos , " you wold be surprised " were his words , most of the main tractor brands....!
And everyone knocks fram ..?
We had a 150hp JD with over 10'000 hrs that had a fram oil filter collapse and seized the motor back in the 90's . Fram stood the bill for a new short engine without any fight , yes we had some costs but we came out ahead in the deal :)
Your Fatherinlaw can eyeball filters rolling down the line and tell both the square feet of media area and the micron size? Cooper could build what ever quality of filter by which roll of paper they use in the filter, how many pleats and how long the piece of paper is?
   / Where to buy Oil and Hydraulic Filters at a discount #32
I can write anything on a filter but it doesn't make it the right filter. Buy REAL Kubota filters and fluids. You payed the price for the machine so why not put in the oils and install the filters that meet the designed spec?
   / Where to buy Oil and Hydraulic Filters at a discount #33
But that same filter is going into 2 boxes...... one half the price of the other
   / Where to buy Oil and Hydraulic Filters at a discount #34
to each his own,
just fyi i spent 15 years as a heavy line / diesel tech, i always got a little grin when somone saved 2 bucks on a cheep fuel filter then had to pay me diag time plus have a new filter installed because the one they had failied, or they guy that swore up and down he had a engine problem becuse the engine rattled bad on first start up. replace the filter with the correct one that had the correct anti drainback valve and the noise was gone. then there was the big block engines that the oil was cavitating and blowing #7 piston out the side of the block, i spent the entire summer replaing engines, once the engineers got wind of it they sent a rep down, come to find out the engine oil filters the company was using that they bought in bulk were the root cause of failure.
do what you want man i dont care, makes no difference to me. All i am saying is that i have years of greesy fingers, busted knuckels and countless stories about people saving 2 bucks and costimg them thousands in the end. if all filters were created equal this would not be such a big deal.
as for your "what oil do i use" ask yourself this. what MAJOR change has taken place since you bought your bota, that all of us have to deal with? here is a hint 3.47 a gallon today - FUEL! one of the main things that contribute to engine oil break down. The old fuel had sulfer in the fuel which from what i understand provided lubrication, now the new fuel is low sulfer so we have a reduction in lubrication. granted the majority of the lubrication took place in the fuel system (injectors, pump) this "dryer" fuel is introduced into the cylinders, with that in mind the oil we use needs to help take up the slack and prevent as much engine wear as possible.
i use Rotilla synthetic, i have torn down everything from a 3116 cat engine to old 6.5 gm engines and by far the clean engines ran Rotilla. Every engine i own runs some sort of mobil 1 or rotilla and the factory filters. i have had one engine failure on something i owned in my life, i learned from my mistake at the ripe old age of 19.
This is just my experince and my opinion, good luck to you
   / Where to buy Oil and Hydraulic Filters at a discount #35
You must be willingly ignorant of the laboratory tests of various Brands of filters. .
Provide a link to all these laboratory tests about which you are talking. Show me any laboratory test results that show a particular brand of filter is not adequate. Provide me with the evidence.
   / Where to buy Oil and Hydraulic Filters at a discount #36
OK. Since no one else is willing, Ill provide a link NTPOG Oil Filter Review to one attempt to review oil filters. I'll provide some relevant quotes.
"This review contains no SAE or ASTM test data regarding filtration ability or flow information. This data changes often (as do the filter designs) and in some cases is not even available (publicly) from a manufacturer. "
"Even the worst of oil filters will last for 3000 miles without any problems at all, and almost any motor oil will last for 7500 miles."
"but the fact is that just about every brand name non-synthetic oil (or "dino") will last 3000 miles and have almost no significant wear to the oil or engine"
"The FRAM x2 (and only the FRAM x2 Series) is probably the most heavily constructed filter I've seen so far."
"No claim as to the reliability or performance of any filter reviewed here is made."
"The information presented here is intended solely to help you determine which filter is right for you from the stanpoint (sic) of construction. "
Anyone know what the the equivalent conversion to miles to hours would be? My guess, on average, about 100 hours, but for sure between 50 and 150 hours. My Kubota calls for oil changes every 100 hours and oil filter changes every 200 hours. I'm lucky to get 60 hours in a year. So with an oil and filter change once a year I'm safely within the recommended use of any filter or any oil. BTW, like most people, I change my filter every time I change my oil. So I'm never anywhere near exceeding Kubota's recommendation for changing the oil filter.
I did not even know this report existed until I did a google search a few minutes ago. I think it supports my contention that any filter you buy is adequate and no tests are available showing an inadequate filter brand. If you can find any scientific report that says any particular filter is not adequate please provide a link. I'd loved to be convinced.
BTW, It would be nice if the next person to call me ignorant would at least provide some data supporting their contention.
   / Where to buy Oil and Hydraulic Filters at a discount #37
to each his own,
do what you want man i dont care, makes no difference to me. All i am saying is that i have years of greesy fingers, busted knuckels and countless stories about people saving 2 bucks and costimg them thousands in the end. if all filters were created equal this would not be such a big deal. as for your "what oil do i use" ask yourself this. what MAJOR change has taken place since you bought your bota, that all of us have to deal with? here is a hint 3.47 a gallon today - FUEL! one of the main things that contribute to engine oil break down. The old fuel had sulfer in the fuel which from what i understand provided lubrication, now the new fuel is low sulfer so we have a reduction in lubrication. granted the majority of the lubrication took place in the fuel system (injectors, pump) this "dryer" fuel is introduced into the cylinders, with that in mind the oil we use needs to help take up the slack and prevent as much engine wear as possible.
Experience speaks; works for me... Rotella and OEM filters are my choice. I pay the asking price and do not know where is best to get discount prices. Dooley's in Athens, TN has always been good to me with prices and shipping right to the front door.
   / Where to buy Oil and Hydraulic Filters at a discount #38
I do 't know why you are trying to pad your opinion with proof such as $100 filters vs $5 filters? If you were honest you would be comparing a $5 filter to a $7 filter.
Let me try to explain. Let's suppose no $5 filters existed. And only $7 and above filters were available. When a comparison was made between the $7 filter and the $9 filter there would be enough quality construction differences for some people to say don't buy the $7 filters because the $7 filters are sure to fail before the $9 filters. Some people would say, spend the extra $2 for the peace of mind. I'd still be saying that the cheap $7 filters were adequate because no data or tests exist to demonstrate otherwise. And people would still be calling me ignorant even though they can't or won't provide any evidence to support their claims.
Also if the $7 filter is better, why not a $9 filter which would be better yet, why not a $25 filter which would be better yet, why not a $100 filter which would be even better. How do you chose which one to buy? There is no question they all meet the minimum requirements. Why would anyone buy anything but the $7 filter. I suppose if you operated in some particularly harsh environments, like battlefield conditions, you'd buy the $100 filter. But if you are like me, where the consequences of an oil filter failure are not life threatening, I'd buy the $7 filter.
   / Where to buy Oil and Hydraulic Filters at a discount #39
Sorry for my ignorance and the slight derail but what's the difference between kubotas hydraulic oil and the stuff at tsc that's $35 for 5 gallons?
Brett
   / Where to buy Oil and Hydraulic Filters at a discount #40
Brett
On my GST the SUDT made shifting quicker and less clutch chatter and on the hydro units it is more quiet. People have also had better results in the VHT range of use on the RTV line.
David Kb7uns
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A52576)
2005 INTERNATIONAL...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
