Where to buy shaft end seal for log splitter pump?
   / Where to buy shaft end seal for log splitter pump?
It should have some number printed on the side.
There are plenty of suppliers that can get that part based on the number.
If you need help finding a supplier PM me.
Thanks, unfortunately the side of the seal that would have markings got eaten up by the shaft key.
As long as dimensions are correct....it should seal.
Some have a green or red coating on the metal also. I think C-R (SKF) calls it bore-tite
I was wondering about that, and want to take a closer look at the pump housing where the shaft pokes out to see how the seal is meant to sit in there and seal up against everything.
   / Where to buy shaft end seal for log splitter pump? #13
I know they are not near you but around here I would go to Hook Industrial Sales - they are a hydraulics repair shop that carry a lot of different seals. I know if they did not have it they could get it for me. You should have an industrial hydraulics shop somewhere near you that could do the same.
the other place would be Motion Industries - since you have all the dimensions they would be able to order it. they have a lot of sales offices around the US- not sure if they are in your area.
   / Where to buy shaft end seal for log splitter pump? #14
Go to Grainger Industrial Supply - MRO Products, Equipment & Tools and search for Rotary Shaft Seal. Go down the list and match up the seal type and dimensions. They carry metric and SAE. Beware of looking too much at their online catalog.........or have a mop handy to clean up the drool puddle.
So turns out this seal is a bit unique and none of the usual supply houses had it listed in their online searches. Only one I found with all three correct dimensions was this one:
Shaft Oil Seal
The inch dimensions are within 0.001" of what I measured and the mm dimensions match the specs I found on the website for the pump manufacturer. This one is a different material, but should still be fine for this application.
Amazingly, it's available on Amazon for $1.80 each. I ordered 3 of them to offset the $4.50 shipping cost and that will give me a couple spares to have on hand.
   / Where to buy shaft end seal for log splitter pump? #16
Has Dirty Hand Tools been of any support?
Have not heard back, but I didn’t contact them until late Friday so I wasn’t expecting a reply over the weekend.
Truck Absorptions Attenuator (A54865)
Truck Absorptions...
2015 Nissan Sentra Sedan (A55758)
2015 Nissan Sentra...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
20'x30' All Steel Carport (A53316)
20'x30' All Steel...
2013 Ford E350 Box Truck (A47477)
2013 Ford E350 Box...
