Where to buy unusual size U-bolt?
   / Where to buy unusual size U-bolt? #11
My 1999 F250 Super Duty 4x4 uses 3" wide leaf springs/ubolts - just got new ones for the rear springs a couple of months ago. The rear bolts have the rounded U and the front springs use the squared U - take your pick and order appropriately.
   / Where to buy unusual size U-bolt? #12
If you want it to look better get some rod and and thread the ends and bend or you could use bolts and a piece of flat steel say 1 1/2 in wide and put two holes in it.
   / Where to buy unusual size U-bolt? #13
Three inch is a common size and should be widely available. Try the already mentioned places or a spring shop will likely have them made and on hand. If you make it as far as a spring shop don't be concerned. Most any I have ever seen look like a throwback to the middle 1800's.
   / Where to buy unusual size U-bolt? #14
You could check an auto parts store. 3" is a common exhaust pipe size.
   / Where to buy unusual size U-bolt? #15
I've got them before for a pipe top trailer from a muffler shop.
hugs, Brandi
2007 Sterling Acterra Dump Truck (A51691)
2007 Sterling...
2015 New Holland TS6.130 4WD 130HP Agricultural Tractor with Alamo Slope Mower (A55787)
2015 New Holland...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55788)
2015 Chevrolet...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
Nissan MCP1F2A20LV (A47477)
Nissan MCP1F2A20LV...
