Where to find older Ford specs?
   / Where to find older Ford specs? #1
40_acre_mule
South Mississippi
Kubota L4701
I've got a 1973 (or earlier) Ford 4000 farm tractor.
Anybody know where I find out such things as:
weight
engine horse power
PTO horsepower
3PH lift capacity
3PH category (how do you tell the diff. between cat. 1 and cat. 2?)
   / Where to find older Ford specs? #2
Ford
4000
Manufactured: 1962 - 1975
Cost: (US Dollars) $3,500 (1975)
Power:
Engine (HP): 55
Drawbar (HP): 41
PTO (HP): 46
Engine:
Fuel: gas
Cylinders: 3
Displacement (ci): 192
Compression:
Rated RPMs:
Firing order:
Oil capacity (qts):
Manufacturer: Ford
Engine:
Fuel: diesel
Cylinders:
Displacement (ci): 172
Compression:
Rated RPMs:
Firing order:
Oil capacity (qts):
Manufacturer:
Transmission:
Type: Dual Range
Forward: 8
Reverse: 2
Transmission:
Forward: 10
Reverse: 2
Capacity:
Fuel (Gal): 16
Cooling (Qt): 14
3-Point:
Category: I,II
Lift (lbs): 3200
Power Take-off (PTO):
Type: independent
Speeds (RPM): 540
Hydraulics:
Type: open
Capacity (gal):
Flow (gpm): 5.4
Outlets:
Tires:
Front: 6.00-16
Rear: 12.4-38
Dimensions:
Weight (pounds): 4375
Wheelbase (inches): 84.5
Length (inches):
Width (inches):
Height (inches):
Serial Numbers:
www.tractordata.com
hope this helps
murph
   / Where to find older Ford specs? #3
Here is a link to the Tractor Data website for your tractor.
Ford 4000
You are in luck the 3 point lift is both cat 1 and cat 2, this refers to the size of pins used to lift the attachment, I have some equipment that came with a combination pin for both, so that it could be used on either.
Wow!
Thanks, y'all.
Exactly what I needed. /forums/images/graemlins/laugh.gif
2013 International WorkStar 7500 T/A Altec D3060BTR Insulated Digger Derrick Truck (A55973)
2013 International...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
New/Unused CFG Industrial MX50R Mini Excavator (A57453)
New/Unused CFG...
New/Unused AGT Industrial YSRT14 Mini Skid Steer (A57453)
New/Unused AGT...
2015 CASE 621F WHEEL LOADER (A58216)
2015 CASE 621F...
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
