Where to get large diameter PVC pipe or tubing
   / Where to get large diameter PVC pipe or tubing #1
Mosey
Conifer, Colorado
2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
I have this crazy idea to try to make a water slide for the kids. I won’t need a ladder or anything, since I have a 15 to 20 degree hill available right in the back yard (they're only 6 years old, so they don't need to go too fast). My plan is to put an inflatable pool at the end for them to splash into and use a small pump to pump the water from the pool to the top of the slide. The hard part, and probably expensive part, is figuring out what to make the slide out of. The only idea I have so far is to use some kind of large diameter pipe or tubing, at least 18 inches in diameter and smooth on the inside, and cutting it in half to get a U shaped slide.
How big do they make PVC pipe? Any other ideas for what to make the slide out of?
   / Where to get large diameter PVC pipe or tubing #2
Since the lil munchers are so young, why not a Fisher-Price plactic sliding board or a plastic one from a swing set at Toys R' Us. De-burring and rounding the edges of the PVC might be a pain in the behind, and if you miss a spot could be a pain in the behind for the lil ones too.
   / Where to get large diameter PVC pipe or tubing #3
Danny, you can get PVC culvert pipe pretty big but make sure you get the double wall stuff. That corrugated single wall could make for a painful ride down /w3tcompact/icons/wink.gif
I always see a lot of the stuff at Carter Lumber in our area. Also try a plumbing supply house. Ours didn't carry it but directed me to a place that does /w3tcompact/icons/smile.gif
   / Where to get large diameter PVC pipe or tubing #4
Wow!!! Very ambitious!! My kids get a much simpler "removable" version kind of like the <A target="_blank" HREF=http://www.qualityrecreation.com/w90072.html>slip 'n slide</A>. Basically, just some heavy duty poly cut to about 3' wide pinned down at the edges with landscape pins. Works great with the water flowing down it....and at the end of the day it gets folded up and the grass is barely dented! /w3tcompact/icons/smile.gif
Kevin
I got them a slip and slide last year and it tore apart when they slammed into the end of it. Of course, I set it up so they could slide down the little slide on their swing set and get up more speed!
   / Where to get large diameter PVC pipe or tubing #6
Make sure the pipe is UV stabilized. I picked up a leftover piece of PVC pipe a number of years ago with the same idea. As things sometimes go around here, the pipe sat for a year or so without any activity on the project. One day I noticed the pipe had split. Whe PVC pipe breaks, it leaves some nasty edges...........chim
   / Where to get large diameter PVC pipe or tubing #7
form trough with clean fill sand and line it with 6 mil plastic or pvc shower stall liner sheeting in 5' widths and fix soaker hose to crest to keep slide wet
   / Where to get large diameter PVC pipe or tubing #8
Mosey,
Oh ya...I'm not saying buy them a slip n' slide...they are too cheap!!! My parents bought the "grandkids" a slip n' slide to use at Grampa and Gramma's house. I think it lasted about 1 1/2 hours /w3tcompact/icons/crazy.gif. Then we made one out of very heavy duty poly. Still using it.
Kevin
   / Where to get large diameter PVC pipe or tubing #9
Mosey,
Have you thought about pond liner or the roll rubber roofing? Seems that stuff should be though enough to slide on without tearing up, and would be easier to dispose of after the kids get too big to play with it anymore.
SHF
   / Where to get large diameter PVC pipe or tubing #10
Another possibility would be talking to some swimming pool companies about old or faulty vinyl pool liners. I know this 'cause we are in the process of replacing ours again - second time in three years - the first one lasted 18 years and was replaced two summers ago. Now the company (bless them) is replacing this two year old one under warranty because a seam was not finished properly - the removed liner works for decorative pond liner, waterproofing around the end of a culvert, lining a cracked birdbath, etc, etc.
Bob
   / Where to get large diameter PVC pipe or tubing #11
I don't know about the pond liner, but the rubber roofing (I have some) would not work as a slide. Not unless it was close to verticle. It is not slippery - at least dry. Maybe oiled up it might work, but that gets a little kinky.
   / Where to get large diameter PVC pipe or tubing #12
Irrigatio/sprinkler, and underground utility companies deal in plastic pipe the size you need.
Soundguy
   / Where to get large diameter PVC pipe or tubing #13
I'm not sure, but I think the pond liner and rubber roll roofing are about the same material, aren't they? (EPDM?)
SHF
   / Where to get large diameter PVC pipe or tubing #14
I had a similar idea last year and talked to a sprinkler/irrigation company. They wanted $400 for a 12' piece of abs pipe (I think it was 18" dia).
Cheaper to buy a roto-molded slide from a playset supply company, similar price but you get a nicer looking finished product.
   / Where to get large diameter PVC pipe or tubing #15
We did a state prison job a while back, and they had two different types of "rubber roofing". One was the Firestone or Carlisle EPDM black stuff you see all over the place. But on the kitchen roof, the roofing was white in color, and more slippery than snot on a doorknob. We went on this flat roof a few times, and it was real slippery even from dew in the early AM. I was on it once when there was some slushy snow, and it was a challenge to stay on my feet. The contractor said it was a different composition because the black material wasn't as resistant to the grease that would end up there from the kitchen exhaust h fans....................chim
   / Where to get large diameter PVC pipe or tubing #16
I don't know how you'd connect them but you could find a few of those 55 gallon plastic drums. Split them from top to bottom and heat weld them some way. I see them for sale around here on the side of the road for around $15 or so each.
   / Where to get large diameter PVC pipe or tubing #17
We have a water slide at our "Over the Hill" party every summer. We use a long narrow tarp, can't remember where we got it. See attached pic.
Thanks for the ideas. Now that I have some ideas to look for, I'll have to get to some places and start looking at what they have.
   / Where to get large diameter PVC pipe or tubing #19
At our church camp, we used mine conveyor belting. They change it out fairly often and roll it up. When wet, it becomes very slick. If the curves are gradual enough, you can even put banked turns in.
UNUSED FUTURE BOBCAT-E SERIES EXCAVATOR (A60432)
UNUSED FUTURE...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2017 Ford F-150 Ext. Cab Pickup Truck (A59230)
2017 Ford F-150...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2347 (A60432)
2347 (A60432)
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
