Which attachment?
/ Which attachment? #1
sherpa
Platinum Member
North Carolina Mountains
2004 NH TC33D & 2014 NH Boomer 24
Which attachment do you use for getting the crab grass out of you gravel driveway? (I don稚 want to go buy a 55 gal drum of round-up).
sherpa
/ Which attachment? #2
I have used a propane torch to great effect on weeds. No chemicals, and it kills the weeds well. Other than that, a box blade would turn things over well enough in a few passes I would think.
/ Which attachment?
I have used a scrape blade (back blade) several times. I was wondering if anyone has ever tried using a pulverizer to get the grass out of their gravel and if it worked?
sherpa
/ Which attachment? #4
sherpa
Wow you must have a long driveway, that would be 251 acres worth of RU......
A blade, box blade, or York rake will do a good job of leveling the gravel & breaking up any vegitation for 6 months to a year. I prefer the blade or York/ landscape rake set at quite an angle, pull the gravel in to the middle in spring as the drive dries out but is still a little soft, then blade it back out to the sides a bit. Takes 4-6 passes to do a good job. The angled blade will also not set up washboard action, but keep the drive level & smooth. A box blade is harder to prevent the washboard effect.
If your driveway is packed hard & baked solid, might not be a good time to bother trying to do anything.
--->Paul
/ Which attachment? #5
I've been using Pronto from the TSC. It comes in a 2 gallon (I think)concentrate. I mix it about 8 parts water to 1 part chemical. Been using the same jug for a couple of years. I mix about 15 gallons at a time to do the drive. I have a broadcast sprayer on the back of the 4wheeler. This brand costs less than round up and has good results.
REDDICK 3PT SPRAYER (A64278)
REDDICK 3PT...
2001 102"X53' WEST STEP DECK TRAILER (A65054)
2001 102"X53' WEST...
1995 GENERAC 99A GENERATOR (A65055)
1995 GENERAC 99A...
2016 Jeep Patriot Sport SUV. (A64557)
2016 Jeep Patriot...
1000 GALLON FLAT BOTTOM POLY TANK (A64278)
1000 GALLON FLAT...
2201SFL (A64553)
2201SFL (A64553)
