Which B for me?
   / Which B for me? #11
Guys,
Thanks for the feedback. I had a dealer recently recommend the L2800 over the B3030 but I'm concerned that it is too big for my property, if that is possible. I failed to mention in the original post that I have one rotten retaining wall which needs to be replaced and it's in a bit of a tight spot right next to the house plus of course I'm also concerned about storage space in my garage. He is offering the L2800 for $1300 less than the B3030 and feels I would prefer the positioning control to the quarter inching valve.
After reading more posts comparing the B3030 to the B2620, I now have a better appreciation for the tough choice between these two. Same dealer is offering the B2620 for $3500 less than the B3030 which makes the B2620 more appealing price wise but frankly they are all expensive. I guess I need to go see them. I'm struggling to justify the investment necessary for these machines and I don't even have a wife to argue with:). I have been shopping the used market and as you all know that is challenging. I just called on a locally advertised older B8200 with just under 500 hours for $6500 and it was already sold :( so they certainly hold their value much better than most things most of us purchase. Thanks again for your suggestions.
I have similar needs on an even smaller (1 acre) property. I definitely couldn't justify a new machine. I ended up with a '98 B7100HST with a Woods DuAl 145 FEL, a 60" mid-mount-mower (which I don't use), and a 50" Meteor snowblower for $6500. The tractor only had 455 hours on it when I bought it earlier this year, and is in excellent condition. It has done everything that I've asked of it, which mostly consists moving dirt and 2B stone with the FEL, box-blading with a 60" box blade, and final grading/raking with a 60" york rake. As the 60" box blade was a loaner, I now have 66" box blade that I found used, but haven't tried it yet. I'm sure it will be fine.
   / Which B for me? #12
Hi, I own a b2620 for about 3 acres. I dont mow w/ it and use it for mainly the same purposes you described. I recently traded a SCUT to get this bigger machine and couldnt be happier w/ it. I feel for your property size the 2620 would be a perfect fit. Good Luck
   / Which B for me? #13
New member today and my first post!
I'm comparing a BX2660 and a B2620 (leaning towards to B series).
Many have said "determine what you need, and buy the next larger one".
Less than 2 acres to mow, 1/4 mile gravel driveway to maintain and clear snow in central VA, mulch etc...
Also closing for good my 35,000 gallon pool, so have a lot of concrete/bricks/earth to load into the hole.
   / Which B for me? #14
It doesn't Snow in Central Va.... Tell the wife it's to help with Hurricane cleanup.
I have a B7800 and 3 acres and Want a bigger tractor but the current one does a pretty good job.
   / Which B for me? #16
The only problem is Hurricane Hanna barely qualified as a severe storm.
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
2009 Kenworth T800 Tri-Axle Day Cab Wet Kit Truck Tractor (A52377)
2009 Kenworth T800...
2015 Honda Accord Sedan (A53424)
2015 Honda Accord...
