which backhoe?
   / which backhoe? #11
I think the 448 gets you more in the long run--upgrade to bigger machine, resale, commercial use if you decide to etc. I found that the 448 was only about 1K more than the 447 (two dealer prices).
   / which backhoe?
will start the callin. i still need my mid pto/rear scv installed by dealer (wasnt in when machine was ready) should i have the dealer install the backhoe or tackle it myself? is the rear scv enough? or do i need another hydro out?
thanks
   / which backhoe? #13
You'll need the Power Beyond circuit installed to operate the backhoe.
If the dealer is already slated to install the 3rd rear SCV -- let them do the PB and the hoe at the same time.
I don't know what kinds of trees you have or the size, etc. of the stumps; but it's a good thing to have the extra power when you come up against a work project that requires it -- than not have it.
Then you'll be plunkin' down that extra $1K for a hoe rental...
JMO.
Best of luck with your decision.
AKfish
   / which backhoe?
ok, sounds good...this machine gets bigger every day!
   / which backhoe? #15
447 advantages
- trailering
- cost
- light enough to put on a dolly and push into a corner in the pole barn
448 advantages
- stronger hydraulics
- more reach
- works on 3x20 and 4x20 series
- worth 50% more money at the scrapyard :D
I have the 447 and am happy with it.
Either way, I think weight in or on the tires makes a huge difference. Helps a lot with the down force (Think of the difference between a 200 pound man jumping on a shovel and a 80 pound kid). The 447 hoe can drag my tractor pretty easily.
Hustler Raptor Zero Turn Mower (A53117)
Hustler Raptor...
2004 Ford Taurus SE Sedan (A51694)
2004 Ford Taurus...
42013 (A51691)
42013 (A51691)
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
John Deere 4650 Tractor (A53117)
John Deere 4650...
