Which brand of axles?
   / Which brand of axles? #11
Agreed, nothing does as good a job as the palm.
I also DO NOT run oil hubs in anything, even HD steer axles because the seals are just too leak prone. Something that is definately NOT an issue with a good double lip seal and a GREASED bearing installed correctly.
   / Which brand of axles? #12
Modmech have you ever tried a grease gun injecter needle . I've used this and put the needle between each ball bearing and pumped grease in . Seems to put in grease were it's needed
2015 FREIGHTLINER CORONADO 122 SD (A58214)
2015 FREIGHTLINER...
2014 BMW X1 S Drive 28I SUV (A56859)
2014 BMW X1 S...
New/Unused Electric 3-Wheeler (A57453)
New/Unused...
Toro Sand Pro (A56859)
2023 Load Trailer (A55787)
2023 Load Trailer...
2014 Kawasaki Mule 600 Utility Dump Cart (A55973)
2014 Kawasaki Mule...
