Which grease to use and when. HD Lithium vs HD Moly Lithium grease
   / Which grease to use and when. HD Lithium vs HD Moly Lithium grease #21
I'm thinking that I do not want my balls to roll or slide ...... !!!!!!!
   / Which grease to use and when. HD Lithium vs HD Moly Lithium grease #22
Yeah, but U-joints use needle bearings with same roller principle. I the used Moly Aluminum based grease on many of them. Over 708,000 miles on the set of greasable U-joints on my commercial truck. Same vehicle has same miles on steer axle hub bearings. That same grease i have used in hub bearings on several different applications with no problems. There is a lot of dynamics going on to categorically say that moly is bad for roller bearings.
   / Which grease to use and when. HD Lithium vs HD Moly Lithium grease #23
It does seem to make my Ferris hard for the blades to start turning when cold.
When I bought mine the dealer pointed out the fact to me that you needed some rpms when you engaged the deck. He said the Kevlar belt is made to take it. Course 61" is the widest air cooled mower I ever had so it does seem to make sense. The rest of it could be the heavy duty (Industrial Series....IS) running gear takes some foot-lbs to get it rolling.
   / Which grease to use and when. HD Lithium vs HD Moly Lithium grease #24
Has anyone used Jet-Lube Arctic Extreme Cold Temperature Grease? It is supposed to have an operating temp range of -65 to 225 (F) and is NLGI #2 and resistant to road salt. All things that seem to make sense in the North here where -10 to -30 isn't abnormal in the winter and there is more salt on the ground than in a salt mine it would seem.
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2023 ACE SC804050L SANDBOX TRAILER (A54607)
2023 ACE SC804050L...
2010 KMC 3376 Peanut Combine (A55301)
2010 KMC 3376...
2018 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2018 Caterpillar...
2014 CHEVROLET IMPALA 4DOOR SEDAN (A54313)
2014 CHEVROLET...
