WHICH JD ?
   / WHICH JD ?
AndyM said:
Quote:
Originally Posted by rockyridgefarm
4710.
How big is your garden?!!!
You can't have a garden tractor if you don't have a garden! :rolleyes:
Where were you 40 years ago to tell me that when I bought a new Bollens with a tiller on it.
Ya let me break the rule fer 40 years. What have Ya got to say fer yersef ?
   / WHICH JD ? #12
I just finished tilling my garden with a donkey.
   / WHICH JD ? #13
LBrown59 said:
lOOKING FOR A USED JD GARDEN TRACTOR:
Need one that will handle a front blade and a rear tiller.
Want Hydro and hyd lift.
What models would You recommend I check out?
Why? Your signature line describes the accounting on your BX23. Why another tractor? Did you get rid of the Kubota?
Drop the 'hoe and get a tiller. Problem solved.
   / WHICH JD ? #15
LBrown59 said:
Did pulling the plow wear you out?
Now I don't care who you are that's funny!!! :)
   / WHICH JD ?
1*Why another tractor?
2*Did you get rid of the Kubota?
3*Drop the 'hoe and get a tiller. Problem solved.
1* Its to replace my Monkey Wards PowerCrap that I use to mow in the smaller tighter places that I can't get into with the BX23
2*No
3*Neet to use the Hoe and a Tiller at the same time on some projects.
   / WHICH JD ? #17
LB, have you been using David Letterman's writers this weekend?
That's the second good one in one day! :) :D :) :D
   / WHICH JD ? #20
LBrown59,
Why even consider Deere? Doesn't Kubota make something to do what you want?
Krause Dominator 4850-18ft (A56438)
Krause Dominator...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2008 CHEVROLET C8500 DUMP TRUCK (A59823)
2008 CHEVROLET...
2008 Ford Fusion SE Sedan (A59231)
2008 Ford Fusion...
3015 (A56857)
3015 (A56857)
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
