which lower arm setting/ new implements
   / which lower arm setting/ new implements #1
BrettW
Platinum Member
now in S.C.!!
Yanmar FF205D
Guys,
I bought a bush hog, finish mower and box blade. I don't know which hole to hook them up to on the lower arms of my 3pt hitch and I need to get it set before I cut my shafts to length. So, where should I put them and what difference will it make as far as the mowers are concerned?
thanks, brett w
   / which lower arm setting/ new implements #2
<font color="blue"> I don't know which hole to hook them up to on the lower arms of my 3pt hitch </font>
I'm confused here /forums/images/graemlins/confused.gif
   / which lower arm setting/ new implements #3
If you have any kind of manual you should look in it. One of the holes will give you the most weight pick-up. On my tractor it is the one that is in back. The other one gives me the most height but the manual tells me to hook up to the back one. I hope that this helps.
Donald B.
   / which lower arm setting/ new implements #4
I'm confused, too. There's only one hole on each of the lower arms of my 3ph.
   / which lower arm setting/ new implements #5
For sure this is not clear. The pins on the implements go into the ends on the hitch arms. Are you talking about the top link holes at the tractor end of the top link? Mine has three vertical holes to choose from. Any one of those should be fine to use if that's what you mean. I would measure for cut with it in the middle hole if you have three. If this is not what you mean, for gosh sakes tell us. John
OK,
I thought I was going nuts so I went back and looked at my tractor just now.
My 3 pt has 3 holes in the vertical (lifting) rods and 3 holes in the horizontal arms,( the ones that connect to the implement)
Sorry if this is confusing to everyone.
This all came up when I tried to put on my rear blade and it wouldn't hit the ground. My 3 pt was set for the tiller that I have. I'm going to get a longer top link as well so that should let it get to the ground.
I'm very new to all this as you might suspect by now but I really appreciate all the help.
thanks, Brett W
   / which lower arm setting/ new implements #7
Being a tractor newb, I'm not positive, but I think the adjustments on the lifting arms and lower arms are to adjust for more lifting power at the expense of llift height, or more lift height at the expense of lifting power. Closer to the tractor would be more lifting power but not as much height.
   / which lower arm setting/ new implements #8
Brett, if in doubt post a picture. I am most interested is the cutting of shaft's. What shafts do you propose to cut?
   / which lower arm setting/ new implements #9
Micropilot; Okay, here comes my two cents and a question. I have an NH TC35 with the deluxe 3point linkage. On my lower lift arms there are 4 holes. I'm wondering if moving the linkage that runs from the upper liftarms to the lowers closer to the backend [forward] would give me some additional drop on the lowers? I'm asking in the hope of getting a little more depth when using a PHD. My owners manual is sufficiently vague on this info. If anyone else is confused, so am I. /forums/images/graemlins/confused.gif
   / which lower arm setting/ new implements #10
Yes, John, the holes closest to the tractor will let the lift arms go the lowest.
Year: 2007 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A51694)
Year: 2007 Make...
2020 Case CX245D SR Excavator (RIDE AND DRIVE) (A50774)
2020 Case CX245D...
2008 Ford Escape XLT SUV (A51694)
2008 Ford Escape...
2018 CATERPILLAR 336FL EXCAVATOR (A52141)
2018 CATERPILLAR...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52748)
Kubota 24in Quick...
Skid steer auger plate (A50322)
Skid steer auger...
