Jerry/MT
Elite Member
- Joined
- Feb 2, 2008
- Messages
- 3,141
- Location
- North Idaho-The Palouse
- Tractor
- New Holland TD95D, Ford 4610 & Kubota M4500
I'm a newbie to this forum and owning tractors although I've been browsing this site for about six months since acquiring an old Ford 1700 farm tractor. I'm pretty much a neophyte when it comes to matters of tractor mechanics, hydraulics, and lubrication although I've been trying to educate myself through this forum. That being said, I have a very basic question that seems to me should be very simple but the more I read on this forum and the service manuals the more confused I get. I want to top off the transmission/hydraulic fluid in my tractor - the original owner's pamphlet says to use M2C134A, the Ford service manual for this model says to use SAE 80 - obviously neither are available at your local Walmart. An Internet search of M2C134A produces a lot of technical sites but also an ad from TSC which it sounds like quite a few of those on this forum buy from - they have "Traveller Universal Tractor Transmission/Hydraulic Fluid" on sale but no specifications assuring me that this is really what I want. Also on the Internet is "Lucas Universal Hydraulic Fluid" advertised, "compatible to Ford/New Holland M2C134A", but it sounds more like straight hydraulic fluid by description and they talk of its use with automatic transmissions. Help! Surely it can't be this difficult to top off some fluid! My apologies to the fact that I am sure that this question has been addressed multiple times - I really have been studying the Lubricants and Hydraulics Forums so as not to be so redundant. Thanks for any help.
When someone quotes a SAE 80W oil, you need to get the required API GL number for it. For some old tractors, like the Ford N Series and the Ferguson TO20 and TO-30, a SAE 80W GL-1 oil was speced by the OEM in winter and a 90W GL-1 was recommended for summer use. This was an oil that was used in the transmission, the rear axle, and the hydraulics. This GL-1 is a straight mineral oil and was superceded by MC134 spec oils and I think that oil is up to the D suffix.
I don't know of any tractor that speced to use GL-3, -4 -5 gear oil as a transhydraulic fluid. However I do not claim to know it all. Some of the sulfur additives in straight gear lubes can cause the yellow metal parts to corrode in the older tractors.
So if your owners manual calls for an SAE 80W viscosity oil, find out what API GL spec it requires. I'm sure the Ford MC134 oils are acceptable substitutes for the old GL-1 oils that it was probably designed to use.
