Which pipe to use on hand pump well?
   / Which pipe to use on hand pump well? #1
Champy
Indiana
John Deere 990
Out on our property, we have an old hand dug well lined with stone walls about 3' around. I told my wife that i would build a pump stand and install one of those old-style hand pump/spigots so she can draw water out. My question is what type of pipe should i use down into the well? When going to the local farm stores they have two kinds - Straight galvanized or the black iron pipe. It will be about 10-15' deep and approx 3/4" pipe (can't remember exactly right now). Any recommendations? Would PVC be better? BTW - its not the cleanest well water either, so we're not planning on drinking it, but using it to wash up or clean tools; etc....
   / Which pipe to use on hand pump well? #2
PVC would be far cheaper, lighter and easier to do repairs on. You will want to install a foot valve and strainer.
Why do I need a foot valve? Does this act like a check valve to keep the draw pipe full or primed?
   / Which pipe to use on hand pump well? #4
Foot valve=check valve. You will see check valves mounted at the top or bottom of the pipe on a well that shallow. It will save your prime. You can buy some models that contain the strainer and the valve in one unit. The strainer will keep out the crud that tears up seals and could possibly catch in the check valve to keep it from sealing properly. Deep wells have them installed at the bottom only so there is always 100'-800' of water in the pipe at all times. Suspend the pickup strainer about 2' from the bottom to avoid picking up the crud that settles to the bottom. You will not need to worry about torque bracing like you would if it were a submersible electric pump. They have braces to keep them from bouncing around in the well casing. You should be able to suspend the pickup pipe from a solid mounting surface at the top of the well.
   / Which pipe to use on hand pump well? #6
Champy
If you are using a pitcher pump the pipe and pump will have to be pulled if and drained in freezing weather
Most of the pitcher pumps are 1 1/4 " pipe thread.
If not used too frequently leathers might dry out and you will have to prime it every time.
tom
   / Which pipe to use on hand pump well? #7
We have one at our camp and used 11/4" galvanized pipe. I did not use a foot valve and we just prime the pump each time we want to pull water. Just have to remember to fill the bucket each time. The base of the pump is threaded to accept the galvanized pipe not sure about using PVC pipe. I only needed one section of pipe so it was just as cheap and easy to go with the metal pipe.
One could add a foot valve to the end of the pipe and it would keep water in the pipe so priming the pump would be very quick and easy. Not sure if the water stays in the pump area if you have a foot valve?
Our dug well is about 8' deep so it works fine. It is mostly for looks with us. Have it down at our fish cleaning table.
   / Which pipe to use on hand pump well? #8
Drill a small hole in the Tubing just below the frost level. This lets the water drain back into the well and the pump will not freeze in cold weather.:D Standard practice on hand pumped wells back when there were lots of them!:D
   / Which pipe to use on hand pump well? #9
Egon: If you put a hole in the suction pipe between the water level and the pump, won't that ruin your ability to create suction and get the water up to the pump? You could pump all day and draw nothing but air through the hole.
to clarify my situation......yes it is a cast iron pitcher pump. I am building a small wooden pedestal to mount it on which sits on a steel plate covering the well hole. The pump connection is a 1-1/4" NPT, and I am guessing that normal galvanized pipe will work ok(?).
My plan was to drill a hole in the steel well cover plate to accept the 1-1/4" pipe, and to put a connector just above that with another small (24") section connecting up to the pitcher pump. This way (if needed) I can disconnect the pump/pedestal from the standing pipe without pulling the whole 10' length....effectively using the pipe connector as a stop since it should be larger than the drilled hole....if this makes sense.
I too was wondering about whether using a check/foot valve would lead to freezing up in winter. Is there a way to trip the valve and drain the held water - or is this already getting too complicated? Perhaps I should just leave a bucket there to prime the pump whenever we go to use it on weekends.
   / Which pipe to use on hand pump well? #11
Subject of foot valve: Only if you want to be pulling the pump/pipe during cold weather.
We had a pitcher pump set up for all our water needs back in the 30s/40s on the farm, pour water in to prime, pump several times till water appears, fill bucket, lift handle high would trip the valve built into the pump draining all water (including the pipe) back into the well. I presume the ones they sell now are set up the same way.
Not sure just how it worked when priming but it did in spite of my taking my frustrations out on it regularly. I was the kid carrying two buckets almost as big as me. :).
Harry K
   / Which pipe to use on hand pump well? #12
These pumps work with a pump rod attached to the pump which is set at the bottom of the tubing. Mostly the pumps had leather washers acting as the seal in the pump.:D :D :D
The small countertop mounted ones usually worked from a cistern in the basement, woud be in a heated area and subjected to a maximum lift that deepened on atmospheric pressure.
The deeper wells all the rod pump and pump stand at the top. Pumping the handle got real old real quick if it was a deep well and lots of water was needed.:D :D :D
   / Which pipe to use on hand pump well? #13
A small ~3/16" hole drilled in the pipe below the frost level will allow water to drain out of the top of the pump to prevent freezing. It won't affect the pumping ability.
   / Which pipe to use on hand pump well? #14
Your well would work and look a lot better with a 32' tower and an 8' windmill stacked around it. Tell Mom she won't have to get carpal tunnel pumping the handle that way....
   / Which pipe to use on hand pump well? #15
Not ours. The entire works sat on top of the spring. Of course the water level was only about 2 ft below the valve in the pump also so...
Loosening a set screw or two let you lift the top, the handle, the pump rod and the suction disk with the leather on it right out of th pump body. You could then reach down and touch the flapper which had a knob on it that opened the valve when the handle was lifted high. That 'flapper was right at the base of the pump.
I still don't see how priming the pump chamber would suck water up the pipe though. There had to be something in there to keep the water from draining down the pipe below the flapper valve.
Of course my memory is of things back in the 40s.
Harry K
Harry K
   / Which pipe to use on hand pump well? #16
Harry, you are describing one that will only lift to slightly less than atmospheric pressure. Just like the inside cistern type.:D
UNUSED FUTURE P45-56" MINI HYD BREAKER HAMMER (A60432)
UNUSED FUTURE...
2013 FORD F250 (A60460)
2013 FORD F250...
2023 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A60429)
2023 CATERPILLAR...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2016 Dodge Grand Caravan Van (A59231)
2016 Dodge Grand...
