s219
Super Member
- Joined
- Dec 7, 2011
- Messages
- 8,607
- Location
- Virginia USA
- Tractor
- Kubota L3200, Deere X380, Kubota RTV-X
Yeah, I am smelling some BS on that septic guy's story as well.
Our state also sizes by number of bedrooms, assuming two persons per bedroom. There is no "bare minimum" -- there is what is allowed by the health department, and that's it. You can upsize the number of bedrooms to allow for future expansion. In our case, we have a 3 BDR house being built, but sized the system for 4 BDR to allow for future expansion (ie, addition). This has nothing to do with extra capacity for normal use, but rather, to allow us to continue using the existing system if we ever add a 4th bedroom on to the house. Systems are already designed with plenty of over-capacity given a rated number of bedrooms.
We need to have an area designated for the primary drainfield, as well as an area designated for future use, called the reserve. Normally, expected life out of a drainfield is 40-50 years at a minimum. If a drainfield fails or reaches end of life, you'd install the new field in the reserve area.
Soil conditions play a big part in the size of the system, as well as how it's designed and if it needs "alternative" technology, which can pace or "dose" the amount of effluent going into a drain field. All of this is factored in, with number of bedrooms, when designing the system and requesting a permit from the health department.
As I mentioned earlier, a larger tank will not increase the effective capacity of the system to handle additional load like parties, company, etc. That seems to be a real common misunderstanding. The only time that comes into play is in an alternative system that has a reservoir tank that works in conjunction with metered dosing into the drain field. For a conventional system, the capacity is completely dependent on how much effluent the drainfield can handle. Tank size does not affect that -- once the tank fills up, the flow rate out to the drainfield is the same as the flow rate in from the household. Every flush into the tank is going to push an equivalent amount of liquid out into the drainfield, no matter how big or small the tank is.
