Which snow blower should I order?
/ Which snow blower should I order? #1
hdm1
Nanoose Bay, BC
Toolcat 5600 F series
I have just purchased a new 5600 f series high flow with a bucket and grader attachment. I want to order either a 66" SB200 or a 72" SB200 but am concerned what will work best with wet snow. The dealer has a standard flow 66" in stock and a 72" high flow arriving anyday, my gut is telling me to order a 66" high flow. I would like to get the 72" as I could then use it on my skidsteer but would be disappointed if it performs poorly on my toolcat. My gravel driveway is approx one km long with some steep sections. Does anyone have any suggestions? Also wondering if the F series has any improvements on the four wheel drive system compared to the D series as my dealer had no clue.
/ Which snow blower should I order? #2
The only differences of the two is the 6" width and 25 lb. wieght. Going through deep wet snow with first pass you may have to slow down but after that you could always take a narrower cut with the 72" to get same performance as the 66". This is assuming dealer orders blower with the same motor package. There are 2 motor options avaialbe for the Hi-flow, a 8.0 motor or 9.6. 8.0 gives more fan speed while 9.6 produces more torque with less HP draw on the engine in identical application. Bobcat recommends the 9.6 motor for the 5600 Hi-flow for best all around performance.
I don't think three were any signifcant changes in drive system from the D to F series. Most noticeable change was the engine went from V2003 (2L) to the V2607 (2.6L) for Interim Teir4 complinace.
Thanks Dennis, I will check the motor on the 72" high flow when it arrives at dealership to make sure it is the 9.6.
/ Which snow blower should I order? #4
I have a "D" series TC and I mostly use the 72" SB-200 (hiflow/9.6). Our snow is typically wet, soggy crud. It's a fun day when I get into some decent powder. The blower width has turned out to be important for me as the extra width allows one to cut into the berm next to the road and cut it back while keeping the tires on relatively solid footing. Also, an advantage the "f" may have over the "d" is that it may be easier for exhaust gases to excape when cutting adjacent to a berm that is to the right of the TC.
I've found that the wet crud doesn't cast as far as I'd like to see...however, it is usually adequate. I try to keep in mind that the idea is to cast it just far enough to minimize the energy (fuel) usage and yet do the job. Keep the 7-pin connector between the blower and the TC clean. You'll also want to check the electrical interface between your proposed blower and your skidsteer. If your skid is a Bobcat and it has the 7-pin connector, I believe you'll be in good shape. The 7-pin system is a "CAN bus"...not a KISS "dumb" interface. Interfacing non-Bobcat equipment (or older Bobcat equipment) to a new Bobcat blower could prove to be "interesting".
Thanks Spudgunner, your point on the extra width with 72" is something I hadn't thought of but I agree keeping the wheels on good footing is important so I will definitely go for the 72" high flow with 9.6 motor. My skidsteer does not have the 7 pin connector so I think I will simply leave the hydraulic angle snowplow on skid steer (works very well) and only use the snowblower on the Toolcat.
/ Which snow blower should I order? #6
I've owned both the Hi-Speed fan version of the 72" SB-200 and the Hi-Torque fan version of the 72" SB-200. THe Hi-Torque version would chew thru anything without slowing down at all but it only threw the snow a short distance 8-10 feet at most. The Hi-Speed fan version throws the snow twice as far but I have to take it a little slower in heavy wet or compacted snow.
DEWFPO
Hmmmmm just when I thought I had it figured out! LOL I guess I will have to wait and see what the dealer gets delivered and decide then. Thanks for all of your comments.
/ Which snow blower should I order? #8
I have a sb200 72'' and use it primarily on my Toolcat. It is not High flow, and blows better than my S185 Skidloader. You won't have any problems with the 72''
/ Which snow blower should I order? #9
I just used my SB200 for the first time this week with my 5600 high flow. 13 inches of wet heavy snow. The SB200 78" is standard flow. If I need a little boost I just hold the high flow button on. The blower pump is rated for 25 - 31 gallons/min. The toolcat is rated at 27 gal/min on high flow. But the computer will not let me keep high flow on unless I hold the button.
/ Which snow blower should I order? #10
I just used my SB200 for the first time this week with my 5600 high flow. 13 inches of wet heavy snow. The SB200 72" is standard flow. If I need a little boost I just hold the high flow button on. The blower pump is rated for 30 gallons/min. The toolcat is rated at 27 gal/min on high flow. But the computer will not let me keep high flow on unless I hold the button.
I'm curious how you determined that your blower motor can handle 30 GPM. If it can handle that, it would seem like you have a HF-capable machine. My cynical mind is wondering if the only difference between a standard flow and HF blower is now the blower "computer/controller". That would be amazing. FWIW, the controller on the HF blower will turn the Toolcat's HF on automatically.
If ALL Bobcat blowers are HF-capable, hydraulic-wise, then I'm wondering if you can simply change the controller to the HF version and POOF...yas gotta HF blower. Sounds like it could be a cool hack.
/ Which snow blower should I order? #11
From my user manual. My fan motor 105-1402 is rated at 25 - 31 gpm. This is a SB200 78" on a high flow 5600 toolcat. I use my stump grinder and soil conditioner in high flow from the toolcat also. But I can't use my A300 high flow in high flow. Just standard flow. The A300 high flow is 37 gpm.
Doug O
/ Which snow blower should I order? #12
Fan motor
105-1398 = 12 - 16 gpm
105-1399 = 14.5 - 18 gpm
105-1400 = 16.5 - 21 gpm
105-1401 = 21 - 26 gpm
105-1402 = 25 - 31 gpm
105-1403 = 30 - 38 gpm
/ Which snow blower should I order? #13
As I look at the blower O&M manual schematics, it looks like the controllers between the std flow(SF) and HF are actually the same part (p/n 6678677). I was thinking the HF and SF controllers were different...but it doesn't look so. In comparing the schematics, I see only one difference in wiring when comparing the HF wiring schematic (Page SPEC-5) and the SF schematic (Page SPEC-6). After snow removal season is over, I'd be tempted to simply jumper pins B and A on the OUTPUT side of the controller to see if you automagically get a HF model. That would seem to be one heck of a cheap upgrade if it worked.
It appears that Bobcat may "jumper" (or doesn't) those two pins by use of different VALVE wiring harnesses. The HF p/n is 6734189 while the SF harness is p/n 6734188. This is the VALVE harness, not the 7-pin harness.
Please note that I have NOT tried this myself. So if you try this and the world implodes, don't blame me. ;)
/ Which snow blower should I order? #14
I think the high flow models do have a larger diameter blower fan. I am just spinning the smaller fan faster by holding down my toolcat high flow button. The 7 pin is a digital communications between the attachment and the loader. Its all programing. That is why I must hold down the high flow button. If I remove the 7 pin connector the high flow button will stay on. But then I can't turn the shoot.
I will be taking my A300 in to the dealer soon to have it reprogrammed for high flow. I have changed the pumps and oil cooler for high flow. Plus many other parts.
/ Which snow blower should I order? #15
In my experience, the Toolcat automatically goes into Hi-Flow mode as soon as the 7 pin connector from the SB is attached and when connected to a machine that has hi-flow capability (skid steer or Toolcat). The SB's were available with a high-torque, lower-speed fan motor package that uses all three hoses, and a lower-torque, faster-speed fan motor to throw the snow farther (this setup only uses 2 hoses). They were called the 8.0 and the 9.6 motor package. I have had both and prefer the lower-torque, farther throw motor package. Even though there are tradeoffs, this seems to work better for me. Both units there were SB200-72's.
DEWFPO
/ Which snow blower should I order? #16
Picture of our December snowblowing. Total was 13 to 14 inches.
/ Which snow blower should I order? #17
Another picture
/ Which snow blower should I order? #18
That is really good throwing distance. My machine is a low flow and I got the torque motor so it throws only about 10 feet. Make sure you keep the rotation chain lubed or it will freeze and not rotate.
2016 Kenworth T680 20 Yard Tri Axle Dump Truck (A59230)
2016 Kenworth T680...
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
2013 PETERBILT 587 DOUBLE SLEEPER ROAD TRACTOR (A60430)
2013 PETERBILT 587...
2017 Skytrak 10054 10,000lb 4x4 Rough Terrain Telehandler (A59228)
2017 Skytrak 10054...
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
Swict 72in. Skid Steer Bucket Attachment (A59228)
Swict 72in. Skid...
