Which tractor for the box blade: 35 hp 2wd or 21 hp 4wd?
   / Which tractor for the box blade: 35 hp 2wd or 21 hp 4wd? #1
Rod in Forfar
Platinum Member
Forfar, Ontario, Canada
1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
My TAFE 35 hp 2WD has a good loader with a leveling feature and 5' bucket. It has loaded agricultural rear tires and the Massey Ferguson float system on its 3 pt hitch.
My Kubota B7510 HST has no loader, turf tires, 4WD, and up-and-down 3pt hitch control. I use chains to the corners of mowing implements to maintain height control.
The job is to landscape around the new houses of a couple of friends in the area. I already have a good quality 7' 3 pt hitch blade. We also own a 4X7 dump trailer matched to the Kubota.
One task involves pulling sand fill out of an area next to large windows (under a deck 8' above), then moving coarse washed gravel into the space created to aid drainage. I'm a little twitchy about using the 7' blade and the bulky tractor in that space and would prefer the control that I think a 4' box blade would offer.
My question is: how much usability would I give up in going with the small box blade? The 5' 6" wide TAFE is a good, steady worker, though hampered on slopes by 2WD. With sun cap it stands about 7'3" tall.
Both lots involve slopes.
I have never used a box blade, though I am pretty good with the 7' blade.
   / Which tractor for the box blade: 35 hp 2wd or 21 hp 4wd? #2
If you are going to be working in close quarters get a box blade for the Kubota. If you are not worried about the extra size and weight of the TAFE get a box blade for it. You could get box blades for both.
Yamaha Jetski With Trailer (A47484)
Yamaha Jetski With...
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A46877)
2009 Freightliner...
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
2003 Chevrolet S10 Pickup Truck (A44572)
2003 Chevrolet S10...
2015 Freightliner M2 106 Medium Duty Service Truck (A44571)
2015 Freightliner...
2025 Wolverine TR-26-02C Class 2 Quick Hitch (A47484)
2025 Wolverine...
