Which Tractor to buy
   / Which Tractor to buy #1
Miles
I need some help on selecting a tractor. I have been deciding between 2 different ones. The first is a 2001
B7500 HST FEL, with a rototiller, box blade and rock rake with 33 hours, pretty much New. The attachments come with the deal. The second is a is B20, FEL with 900 hours. The B20 is actually $1500.00 less but is an older machine. I have 6 acres but no fields to mow. It would be used generally for landscaping, post holes etc. I don't know if the bigger machine is better for personel use or if the 7500 will be ok. I also just had someone talk to me about L2350 which I don't anything about and how it would compare with the other two. Any info would be greatly appreciated.
   / Which Tractor to buy #2
Miles, the B20 was specifically made for a backhoe; does this one not have the backhoe? If it has the backhoe and you need a backhoe, then I'd say that's the one to buy. If it does not, and you don't intend to get a backhoe, I'd say go for the B7500.
2012 Bobcat A770 Compact Wheel Loader Skid Steer (A44571)
2012 Bobcat A770...
1500 Gallon Water Tank (A47484)
1500 Gallon Water...
2025 Wolverine BC-13-72W UNUSED 72in Brush Cutter (A47484)
2025 Wolverine...
2025 LandHero Mini Excavator (A45336)
2025 LandHero Mini...
2013 Ford F-150 Pickup Truck (A44572)
2013 Ford F-150...
2015 Chevrolet Silverado 1500 (A45336)
2015 Chevrolet...
