Which would you buy? (Help me spend my money)
   / Which would you buy? (Help me spend my money)
I really don't getting the whole "Kubota is so high priced" thing either. My shopping showed it was only a slight bit higher and that was negligible if you take advantage of the 5 year no interest deal.
I'm sure it depends incredibly on dealer, location, etc. and yes, Kubota has much better financing terms. But for a cash purchase, which I'll be making, the actual hit to my wallet for the Kubota with the lowest HP and lowest lift capacity is $5k more than the LS, and $10k more than the TYM. When talking about my hard earned money, that's a lot to me.
   / Which would you buy? (Help me spend my money) #72
I think the OP is very intelligent and is trying to do due diligence, but he's inexperienced and like most inexperienced people he places too much faith on specs & brochures.
My advice is consider the probabilities of break-downs of a machine like Kubota vs Ls TYM and others and then check where you can go for service and HOW QUALIFIED that service is.
If you don't depend on the tractor for a living and the price difference is great and you'll keep the machine forever then any brand will do. If you are planning to upgrade later and you have an off brand machine you'll lose your shirt on trade-in. Only you can decide what's best for your situation.
Personally, I have an LS because I bought used and found a steal. But now that I've operated it for a while, loader strength would not have been a deal breaker if I'd found a deal on a Kubota. Even with a 700 lb rotary cutter counter balance, my front end is heavy with ~750-1000 lbs of dirt in the loader. It'll get stuck in wet grass in 2wd, tires are noticeably sitting low, slight bumps going down hill will make the back creepilly light, etc. With no counter balance, the back tires lifted and a dumped the bucket and hooked up my cutter while recovering from a heart attack. As a relatively inexperienced operator, I don't want any part of lifting the load my loader is rated for, at least if I have to drive far. Lifting a load while someone backs a trailer under it, maybe. Driving across the yard with 1800 lbs of anything, no thanks.
Thanks for your experience. I'm not familiar with your tractor model. Does it by chance have the stupidly small front wheels like the XR3135/3140 has? That's one thing I am not at all fond of on the 3100 series LS.
That is an incredibly astute, and accurate observation. Except, maybe, about the intelligence aspect.
   / Which would you buy? (Help me spend my money) #75
This is your party, your money, but if I were you, I would put a bit more credence on the real-world experience of TBN forum members and what they are sharing, vs. spec's on a sales brochure. If sales brochures are your trump card, no need to even post here. Just get the best on-paper tractor.
   / Which would you buy? (Help me spend my money) #76
I am always open minded with other brands and I love to discover a truly good value with a new brand. But over and over with tractors at least, other brands make me appreciate my Kubotas more. Sometimes it's little stuff that you wouldn't always think about up front, or stuff that doesn't translate to paper. Sometimes its stuff you only discover after using the tractor for a while. So while I am open minded, I sort of keep proving to myself that if I don't want surprises and I want to be able to take things for granted, then stick with Kubota. In my mind they are like the Honda of the tractor world. Maybe more expensive and certainly not perfect, but they do their homework, they build a good product (with control over almost all the components from engine to HST to chassis to loader, unlike almost every other brand), and it's a known quantity for me. They also stand behind their products which can be an issue with other brands.
I remember when my neighbor got his Mahindra, I looked it over and thought, nice tractor. Then I noticed no suspension on the seat. Then I noticed the loader valves were real abrupt feeling with none of the finesse or fine control I was used to in my Kubota. Then I noticed that his loader rating, which was higher than mine despite his tractor being one size down, wasn't worth the paper it was printed on because the smaller tractor was simply not stable with heavy loads, and the loader itself had a real limited reach and height. Finally, he's had several warranty issues and they have all been a struggle (one of his Mahindras has sat at a dealer for months while they are in a game of finger-pointing with corporate). I had a similar experience with a Deere E model and an LS. On first glance they all looked good to me but it wasn't until some time in the seat that I started noticing some sore spots.
I think all the brands are quite good overall, especially if you can ferret out who makes the tractor and components that go into the other brands that don't cover the "soup to nuts" process Kubota has, and can ensure you are making a good choice. And all of the brands will get the job done, no question about it. Rural King seems like the one to beat right now, if you want one of the second tier brands at a bargain price.
Kubotas are going to be more expensive, but I feel like they have earned their reputation and there is a reason they have 50% of the market for compact tractors despite being more expensive. Whether or not that is a factor depends on the buyer and what's important to the buyer. If price is the only true reason someone passes on Kubota (I've said many times that loader specs are not a real reason**) then it's important to make sure the cost savings justify going with one of the other brands. Based on what I have seen with some of the other competing tractors I have run, the cost savings wouldn't make up for the annoyance with some of the factors I mentioned above.
** Also compare tractor weight of course. Sometimes Kubotas are lighter tractors and the loader capacity goes hand in hand with that. If you are after the heaviest baddest tractor out there with the stoutest loader, it's probably not going to be a Kubota, or at least not a B or L model (look at MX, etc).
Very valid points. Thanks for the well thought out suggestions.
   / Which would you buy? (Help me spend my money) #78
You still haven’t answered my question as to wether you have any tractor experience or have used any of the tractors that you are passing judgement on!! You can hammer all the paper facts you want, but until you sit on the seat and actually do work with it, the paper facts don’t have much meaning. You say companies don’t lie on their facts and that may be true, but they certainly choose which facts to share and which they don’t.
The second part of your question was asked and answered in posts 1 and 9. Yes, I have sat on and driven every single tractor, operated the loaders, checked ergonomics, looked under the hood for filter placement, etc., made real life measurements to compare width, height, etc., and talked extensively with each of the dealers.
As to the first part, I have admittedly very limited experience. A few hours on a friend's B2650, and a day renting a JD and box blading with it.
   / Which would you buy? (Help me spend my money) #80
Sorry but this is easy answer. Get the Kubota. The grand L’s are the highest quality compact tractor made. And I think you will find loader had plenty of lifting ability for size of machine. 90” of snow blowing... cab is a must.
2015 Freightliner M2 106 AWD Versalift TMD2047T Insulated Digger Derrick Truck (A55973)
2015 Freightliner...
2020 Caterpillar 259D3 Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
Truck Metal Cargo Storage Box (A55788)
Truck Metal Cargo...
2012 Mitsubishi Fuso FEC52S Cab and Chassis Truck, VIN # JL6AMG1A0CK003828 (A57453)
2012 Mitsubishi...
Greenworks 2700psi Portable Pressure Washer (A56857)
Greenworks 2700psi...
2023 Chevrolet Tahoe (A54815)
2023 Chevrolet...
