whiffs of HST odor while using tractor?
   / whiffs of HST odor while using tractor? #1
BotaBX24er
SC
Kubota BX24
I've noticed this since the first time I smelled what HST fluid was like (after 50 hour service, but didn't think anything of it. Now that I've been educating myself on TBN, I'm wondering is it OK to get whiffs of HST odor while using the tractor? I thought that the HST was a completely sealed system :confused:...is that an indication that I may have a pin leak somewhere? I haven't noticed any fluid on the lines, but then again my BX24 has been covered up in mud lately :p...
   / whiffs of HST odor while using tractor? #2
There are breathers on the case of the transmission and it is common to smell the odor of the fluid once in a while.
   / whiffs of HST odor while using tractor? #3
I know just what you mean. We have a different model, L3830HST, but I think it's the same deal. I was concerned, too, untill I figured out what it was. On ours there is a breather tube on the filler cap. When the 3PH or the loader goes up and down the fluid level rises and falls, so there has to be a way for air to come in and go out. When the air is forced out it smells like the HST fluid. The fact that the level goes up and down is why you're supposed to lower all attachments to the ground before checking the level of the HST fluid. Probably if you filled the HST fluid with the attachments in the air, it really would be fluid coming out, and you'd have more smell!
Randall, Jim,
Thanks for the response. Now that you say that, I did notice it more while using the BH and probably because I'm not moving as much either.
   / whiffs of HST odor while using tractor? #5
Another factor would be the HST temperature, which will be higher the harder you work the machine. The hotter the fluid gets, the more you will smell it. You will get accustomed to the odor, you may even grow fond of it! (Don't EVER dab it on the wife's neck, she won't understand)
   / whiffs of HST odor while using tractor? #7
Actually, all the hydraulic fluid is common. The HST uses the same reservoir of hydraulic fluid as the loader, the 3 pt hitch, power steering etc., they all contribute to the heating of the hydraulic fluid and thus the volatility of the oil. All tractors vent the hydraulic fluid.
2016 New Holland B95CLR Loader Backhoe (A50860)
2016 New Holland...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
1996 Ford F-350 Mason Dump Truck (A48081)
1996 Ford F-350...
(1) 10ft Livestock Panel (A48837)
(1) 10ft Livestock...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A50505)
2019 PETERBILT 579...
UNUSED MOWERKING SKID STEER HD FLAIL MOWER (A50460)
UNUSED MOWERKING...
