white hydraulic oil
   / white hydraulic oil #11
Is it milky, or can you see through it. clear, red, blue or yellow, it should be translucent.
   / white hydraulic oil #12
did the mechanic actually look at a glass jar full or did he just have a tiny bit on his finger? There is no way to tell just by feel. When in doubt, do the change and clean out, instead of having an issue/worry.
   / white hydraulic oil #13
ideally, you will not have to keep refilling and wasting GOOD oil. that's why I gave the instructions I did. the alcohol in the mix will DISOLVE the water. water is polar.. alcohol is a polar solvent. thus water is carried out in soloution. the diesel thins the oil. what you have left in the sump will be very little water and some thinned oil.. if you refill it and then run the machine normally.. you stand a good chance of flashing the remaining moisture off... vs wasting another 5g pail of oil..
if you were just doing oil flushes.. yeah.... it will take a while to get it all out as it emulsifies..
BTDT dozens upon dozens of times.. :)
soundguy
   / white hydraulic oil #14
What soundguy suggests. I went with the straight fluid flush and a handful of changes. I would suggest not going my route but using a solvent rather than hoping for an emulsion. I had a lot of water and now I see none but haven't tried a crackle test.
   / white hydraulic oil #15
If you have any question on if you really have water in the oil, just send a sample out for analysis.
   / white hydraulic oil #16
i think a UOA for the gear oil in an 8n is quite comical... :)
It will be 100% noticable if it is clouded or emulsified.. :)
the price of a good UOA will almost cover a cheap pail of utf oil that could be used as a flush.. or will totally cover the previous flushing agents I mentioned, and pay a lil towards the new oil going in.. thus rendering the question of 'if' a bit of moot point.
soundguy
2014 INTERNATIONAL MA025 (A52472)
2014 INTERNATIONAL...
2003 Pierce Tilt Cab Fire Truck (A51692)
2003 Pierce Tilt...
Fuel Tank (A51573)
Fuel Tank (A51573)
2017 FORD F350 (INOPERABLE) (A52472)
2017 FORD F350...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
Pallet Fees (A50775)
