Whiteish substance in bevel gear/pinion case
   / Whiteish substance in bevel gear/pinion case
Thanks IH. Great info. A couple more questions if you don't mind.
Before I split the track do I need to empty the the track tension jack? How do I make sure there is no compression left in the spring so the idler doesn't shoot or move forward when I split the track, and if it does, what will I need to pull enough track slack back to reconnect it after the seal repair.
Here is a link to a pic of my loader
http://i20.photobucket.com/albums/b249/dcara/Loaderleft.jpg
And one of my spring/jack assembly before I fixed the spring retension bracket
fullspring001-1.jpg picture by dcara - Photobucket
   / Whiteish substance in bevel gear/pinion case #12
The recoil spring will already be against it's stops . Just clean the ram bar of dirt/rust/paint as you probably already did when you fixed the bracket , before releasing the grease so the seal is not damaged by foreign material . You may need to put a block in front of the idler and drive forward with the grease adjuster out to push the idler back . You can also put a large piece of timber between the top of the bucket and against the idler and roll the bucket back or put a piece of solid timber between the sprocket and chain and walk the machine back . All these ways will pull the idler back to allow the chain to become slack .
It may be a good idea to post some photos of the axle oil leak and a couple of shots under the fuel tank as someone on TBN may see something missed and save you some effort .
Thanks again IH for the ideas. Got to get a new camera since I lost mine back in July and my 10 year old cell phone doesn't have one.
2008 CASE 721E Wheel Loader (A47477)
2008 CASE 721E...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A52377)
2014 Ford F-450...
2010 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2010 FORD F750 XL...
