Who makes a good air compressor for under $1000
   / Who makes a good air compressor for under $1000 #31
I understand. But they are actually made for a working pressure of 100lbs psi, and they have a pressure relief valve at 125 psi. and good used ones can be found at plumbing stores all day long. For those that may want to try this, give a good look inside by pulling out both heating elements. You will tell right away if there is corrosion in it or not. Usually the elements just go bad but the tank is fine.
Not trying to talk you in to anything just providing information. I have used mine for 9 years with perfect performance.
Just a simple way to use $500 on something else, right?
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A54757)
UNUSED WOLVERINE...
2014 Top Hat Industries 18FT T/A Utility Trailer (A52377)
2014 Top Hat...
(APPROX 21) UNUSED LANDHONOR PINS (A54757)
(APPROX 21) UNUSED...
23018 (A53424)
23018 (A53424)
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
