ArlyA
Super Star Member
- Joined
- Mar 18, 2016
- Messages
- 13,379
- Tractor
- Outlander1000 6x6, Ego lawn mower and shopping for tractor
Thanks to all who stated the difference in these transmissions.
BrokerMike, what size bushhog do you have now and what size do you want to increase to?
Lot of experience here in how much tractor you need for what size mower.
I do think it's interesting that my Kubota is like an old fashioned GM Powerglide, a two speeder.
Then we went to three speeds, then four, then five, then I think we are up to ten speeds now in cars.
Yet our hydros seem to be standing still at two speeds. Perhaps someone has a three speed by now, L,M,H, but the analogy
to a car trans is pretty strong. More speeds, assuming some ability to "lock up" the trans, has to be more efficient.
Which I think was the design motivation for IVT/CVT; a way to get more gear (torque?)multiplication with a simple push of the lever.
when one hand is on a loader joystick and one hand is on the steering wheel, doesn't leave a lot of hands for a shifter...
We run a 6' brush hog, it's a light duty. would sure like to have a heavy duty rotary mower but they're heavy as heck.
making some big assumptions based on where you live, can we assume hilly ground, some "moguls" or areas that you could scalp with a really wide fixed mower?
Seems the next step up is a batwing 10 footer and you bet, needs a lot more tractor. So for a HD six or seven foot brush cutter, particularly for some land clearing in addition to field mowing, whatever, the real question is will 55-60hp at the pto do it. Most likely will unless you really load it down. Should be a bunch of members here with 4720 JD's. If it were me, I'd post in the JD section and ask if their 4720 tractor could do the following and list what you want to do. I'd pick a new bush hog and list that model too. That will give you real world feedback and not brochure hype. You are likely talking about a 50% increase in power over what you have now, but since we rarely run at full output, not going to see some huge improvement in daily use other than when working hard.
I never loaded the unit down hard but my 50hp pto Kubota HST with loaded tires and a FEL on ran an 84" Land Pride HD bush hog with the a/c going and never budged the temp gauge.
It's really a matter of how heavy a load you will put on the mower. My LP mowers have been superb, worth the extra cost. But a Bush Hog and others I'm sure
are comparable.
I don't remember for sure, but I faced the same delimas. IIRC, to keep HST, no one offers that with the larger 20" + front rims. But like I said, I cannot remember for sure.
Perfect world would be 60hp, in a 4000# HST tractor, with 20" front rims (for smoother ride that a taller tire offers).
Amen. My next tractor will have large front rims (ok, "wheels" for Gmanbart), and I'll take whatever transmission is available. HST would be nice, but a hydraulic shuttle would be a good second choice.
I have a Kubota MX5100 and the one thing I would change if I could would be to larger front wheels. Man that would be great.....
