Who uses torque wrench for mounting mulcher teeth?
   / Who uses torque wrench for mounting mulcher teeth? #1
Timark80
NW FL
78' Ford 2600 - 09' Bobcat T320 l
I plan on renting a torque wrench. I've heard some folks just tighten as much as possible using body weight with a 3/4 rachet wrench.
   / Who uses torque wrench for mounting mulcher teeth? #2
I do not use a torque wrench on the mulcher but I religiously do it on my chipper. The mulcher teeth were a bit much for the torque wrench. After replacing, I use my 3/4 inch impact wrench. I'm always careful not to overtighten (stretch) the bolts or reuse them too many times.
   / Who uses torque wrench for mounting mulcher teeth? #3
That would be the 'grunt' system.
One grunt = 50 to 100 #
Two grunt = 100 to 150 #
Three grunt = 150 to 200 #
I would think this system would be just fine for your ap.
Save the torque wrench for rod caps, head bolts and such.
Grunt system has been used for several years here too. Just wanted to check in on other opinions.
Thanks!
   / Who uses torque wrench for mounting mulcher teeth? #5
If the torque spec is less than 150 just go to Harbor Freight and get a cheepo one on sale and use the 20% off coupon
1/2" Torque Wrench
I think I have seen them on sale for less than this. I have one that is 15 years old and tested it against my buddies freshly calibrated Snap On and it was within 2 or 3 ftlbs. Fine for tires and stuff. They also have a3/4 one that is considerably more expensive. Like $70
   / Who uses torque wrench for mounting mulcher teeth? #6
How big of fasteners are these ?
Allen screws about 4" long with 1/2" hex head. Will be using 3/4" impact for removal then ratchet wrench for installing.
   / Who uses torque wrench for mounting mulcher teeth? #8
Impact off and on, a half inch should do fine.
   / Who uses torque wrench for mounting mulcher teeth? #9
1/2 inch ratchet with a 2ft cheater bar. The ratchet will break before the bolts. If we're at the shop we use the 3/4" impact.
The new teeth install went smooth. WOW what a difference coming from bobcat carbide to the new quadco chipper teeth! I know you have to re-sharpen every day but it cuts so much faster. I also noticed the head was running smoother with less vibration.
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
2012 Freightliner Bucket Truck (A55973)
2012 Freightliner...
Enerpac RCS302 30-Ton Hydraulic Jack, 5" Tall (A59076)
Enerpac RCS302...
55-Gallon Drum of Komatsu Hydraulic Oil HO 56-HE (UNOPENED) (A59076)
55-Gallon Drum of...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2006 Hyundai HL740-7 Articulated Wheel Loader (A56857)
2006 Hyundai...
