Why diamond shaped repair plates?
   / Why diamond shaped repair plates? #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
I have seen it mentioned here that diamond shaped plates should be used to repair cracked plates on tractors and I have seen diamond shaped plates welded onto structures. In fact, my backhoe was repaired with diamond shaped plates that were welded to the larger arm on my Case 580CK backhoe. These plates were welded in place to repair obvious damage to the backhoe. In fact, I have always wondered if the backhoe rolled down a hill or came off of a trailer while going down a freeway at 70MPH because of the damage to the loader arms and the backhoe arms. However, the only repairs that really seemed professional were the diamond shaped plates. These plates were obviously repairs. They were not part of the original structure.
Thanks,
Eric
   / Why diamond shaped repair plates? #2
My grandfathers blacksmithing and weld shop used to repair a lot of truck and trailer frames. The diamond shape was used to help reduce stress fractures that may have been caused by the heat when welded.
   / Why diamond shaped repair plates? #3
My understanding is you need to have weld beads in multiple axes for max strength for repairing a plate/flat surface. A diamond shape provides this and also generally keeps all weld beads at different angles than your part edges. Which further improves strength
   / Why diamond shaped repair plates? #4
Also used for wood instrument repairing cracks. Best shape for distributing stress to an already stressed component.
I'm not an engineer, but I have repaired guitars with these.
Patrick
   / Why diamond shaped repair plates? #5
You don’t want to use a basic rectangle plate for repairs. It focuses the stress more and makes a future crack more likely. A circular or oval plate is the best.
   / Why diamond shaped repair plates? #6
As 4570Man said.
Think of it this way, if you had two pieces of 2 x 2 pine couple of feet long and grabbed each one in a vice from the end. One one scribe a line across it just up from the vice and then try to break both, which one will break first?
Thanks everyone for the quick replies. Of course, once I read the replies they made a ton of sense about distributing the stresses.
Eric
SCAN FOR HAULING AND FINANCING INFORMATION (A54756)
SCAN FOR HAULING...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2014 Chevrolet Cruze Sedan (A53424)
2014 Chevrolet...
2024 Timpte 40ft Hopper (A55314)
2024 Timpte 40ft...
Mini John Deere Truck (A55853)
Mini John Deere...
2022 Case IH 8250 Axial-Flow Combine (A53485)
2022 Case IH 8250...
