Why did this happen?
/ Why did this happen? #1
koop
Bronze Member
Madison Virginia
Case IH 495
/ Why did this happen? #2
Not "normal", but not impossible either. Looks like you nailed a rock "just right" and bent the blade upwards. A couple weeks ago, I caught a rock "just right" with a Bush Hog mower that ended up with the rock getting between the blade end and the deck. That bent the blade downward approx. 6". Put a heck of a dent in the deck and ruined a blade.
After banging for about 10 minutes, I managed to dislodge this blade. When I held it next to the other one, I could not see any significant difference in shape.
/ Why did this happen? #4
I'd take carefull measurements and look closely to see if the stumpjumper isn't bent. Something had to give a little to allow that blade to end up several inches out of place. With the blade re-installed, measure tip of blade to deck on both sides. Should be the same measurement OR start looking for something misaligned.
/ Why did this happen? #5
Stumpjumper/hub could be bent. deck/gearbox mount could also be bent. Re-install the blade and measure distance from blade tip to deck with blades fully extended, with the hub rotated around to different places around the rotation. In a perfect world, it should be the same from tip to tip all the way around... the forces involved under a brushhog deck in operation are awesome, and when a high mass immovable object is struck, a whole lot of different things can happen. How are the bearings in the gearbox(wiggle blades up and down and look for vertical play in blade mount or hub movement)?
I will raise cutter this weekend and measure all around to look for uniformity. I did notice that I was able to tighten the nut on non-embedded blade a little. Is it possible that the blade was loose enough to create the play needed to allow it to hit the deck?
What other damage will have occurred as a result of this do you think. I noticed that the shaft still turned when I spun the blades by hand.
Thanks for the help.
/ Why did this happen? #7
IMO, yes a loose blade bolt could contribute to this.
/ Why did this happen? #8
Hogged out hole in the blade for the bolt could do it too.
soundguy
/ Why did this happen? #9
I have wacked a few big rocks and thought that SOMETHING had to be messed up under the deck only to find that things look just fine. Amazing what these things can take.
/ Why did this happen? #10
there are supports for the deck on the underside?
mine are on top with a perfectly smooth underside... i guess it would eliminate that problem..
/ Why did this happen? #11
If I recall right, that is a boxed support beam on the under side of the Wood's brush cutter. A stump or rock at the wrong timing or a loose blade will let this happen. You want to repair the box support not only for strength but also to keep trash from hanging-up and making more problems.
/ Why did this happen? #12
Koop, you've got to change that Avatar. Almost killed my monitor.
/ Why did this happen? #13
Wooo hahaha! Me too! **** fruit flys! Hard to kill those little bahstids! :D
/ Why did this happen? #14
Mine is smooth under the deck as well.
/ Why did this happen? #15
Neighbor of mine, under the influence of an overdose of Saturday morning caffeine hit a rock and opened up the deck as though done with a can opener!!
/ Why did this happen? #16
I've hit my fair share of rocks with the woods, haven't had that happen yet!
Its possible to bend the tail wheel yoke, though, it appears... despite being really heavy steel.
10ft Cattle Panels (A64047)
10ft Cattle Panels...
2018 Trail King Lowboy (A63118)
2018 Trail King...
Arrow Quip EF10 Two Bow Alley Kit (A64047)
Arrow Quip EF10...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
2016 Audi A3 Sedan (A61569)
2016 Audi A3 Sedan...
2014 Takeuchi TS50R Compact Wheel Loader Skid Steer (A61567)
2014 Takeuchi...
