majorwager
- Joined
 - Oct 10, 2017
- Messages
 - 1,062
- Location
 - western new york
- Tractor
 - kubota mx 5100 IH 484 ford 1620 lull 844b
Jeffy,
At the speeds typically traveled by compact tractors, and in consideration of the softer surfaces upon which they are driven, fuel savings are negligible. Prolonged logevtivity is also in dispute. By your own words, compacts accumulate only about 80-100 operating hours annually.
As an example of longevity, I own a 1993 compact w 2000 hrs. Tires never abused, or spun excessivly. Tread depth is within several thirty seconds of the original. Stored inside, so minimal dry checking, or UV degradation. So just how long do you believe these R-3 tires should last?
Michelin reports the tractive effort increase over bias ply is 20 percent +/-. Not sure if that stat is relative to light nature of compacts, 2-1/2 tons and less. Was noted that most construction machines are much heavier, to benefit the radial advantage.
Radials are more expensive and not all sizes are available but selection is improving.
If you truly feel that radials are such a substantial advantage, why have YOU NOT equipped your own tractor w/ this feature?
EDIT::
Bias compact tires are operated at 15 to 18 psi. You allege a softer ride w/ radials on a compact? Ridiculous. You state directly that radials would operate at lower PSI than bias ply. From where is this information obtained, as it is inaccurate. What is the PSI recommendation for TP in your kubota OM? The footprint slightly wider, alas 20 percent more traction.
As for compaction factor using a CUT tractor, radial or bias, is twilight zone science. Where do you source this nonsense?
EDIT::
