Why I did not upgrade to a better splitter
   / Why I did not upgrade to a better splitter #11
I'm 72 and used to go through 20 face cords per year but got tired of sore backs and visits to the chiropractor. About 5 years ago I splurged on a geothermal system which has finally payed for itself. Since I still have the 3 point splitter and other wood tools I make 6 or 7 face cords out of dead ash, blowdowns, and whatever happens in the woods; it's nice to have a hot crackling fire on a wintry night. When it's bitter cold and windy I'll fire up the wood furnace to take some strain off the geothermal.
Best part of this is the pressure is off me; I don't have to worry about getting enough processed for the next winter. I keep thinking that that pile of cherry needs splitting, then remember that there is no urgency, it can wait.
   / Why I did not upgrade to a better splitter #12
My father was in his late 70's when he gave it up, although it was because of his Alzheimers. A couple of times he had the fire department there because he started a fire without filling the boiler with water...
Before then he had given up cutting it himself and would buy 8 foot loads delivered, where it would set for a year to dry. He had a cordwood saw to go behind the tractor and we would spend a weekend cutting the wood. My job was generally taking it off and throwing it into the KB5, then he's take it down and dump it at the house and come back for another load.
When we were cutting big pieve I'd have to brace myself so that he weight of it wouldn't pull me into the blade when it came off the table...
I hated that saw. It was the first thing which went after he passedaway.
   / Why I did not upgrade to a better splitter #13
I rarely split anything in the 5" range, the majority of my wood is blow-downs and LARGE trees to boot. I have to use my splitter (Woods 27 ton) vertically and do 20" length for my 24" firebox. A lot of my stuff is over 30" in diameter and I use my rock bar to move them into place and tip it up. I only do oak, hickory, walnut, cherry and elm. I stack my wood on racks I made and they measure the 20" wide x 6' high x 12' long. I usually go thru 2 - 3 of these racks a year here in TN as supplemental heat and I currently have 8 racks tarped. What I burn is usually stacked for 2 years or a little more. I'll be 66 in a couple of months ...
   / Why I did not upgrade to a better splitter #14
I mostly burn ELM since so much of it dies from disease. . It would be interesting to know how the drying process works. Is there anything unique to ELM? I should know having cut dead elms with my Dad already back in the early 70s. Some trees rot really fast and others are dry and hard as nails years after dying. I HATE seeing all this standing dead wood go to waste. I know ELM doesn't quite have the BTUs of maple.
I have to say, that my Fancy Electronic controlled splitter has been everything I had hoped for.
I addressed the two most annoying things about splitters I had used. I went for quiet operation and automatic split cycle, not having to stand there and wast time while it splits.
Just need to add a table and it will be perfect (for me).
Thanks for the kind words guys.
To answer the question on "loggers cord", it is a made up of 100" logs and stacked 4'x4'. So a bit more than a real cord. I believe some people call it a pulp cord as it is what many of the pulp mills around here specify.
I normally go through 5-6 cords a year but heat with propane as well. I figure about 60-70% wood and 30-40% propane.
I did not mention that I broke my ankle a while back so "manually" processing wood would have been very difficult this year anyway. I got "lucky" when I decided to go with a processor for my needs.
I have another 20 logger cords to process. I will be "smarter" about it this time and pick out the logs that can be cut to length and used. See below:
It will take about two days to do the sorting but I can do it when it is too hot to do much else.. Nice to have an A/C cab tractor!!! One of my friends is a Vet and needs the money so I will likely have him cut all the small logs to length. He loves to run a saw so it works out.
BTW a few of the locals have come over to admire the piles. A few others are looking to piggy-back on our next rental. Rental is $300/day or $450 for two days. With the right logs, it spits out a LOT of firewood in two days. Figure about 7-8 cords per day. By splitting the 2 day rental with a neighbor I can process 7-8 cords for $225 and not break a sweat. Have to love technology!!
Of course, there are downsides. Processor rental costs are bound to go up. As more people experience what my neighbors have seen, rental demand will increase. As demand goes up, users will need to plan better as getting one is next to impossible during the peak season. Lastly, it is not the way to deal with turning "free" wood from logging sites (unmarketable short logs), blowdowns and limbs into firewood. I will be keeping my DR splitter for the "free" wood I get.
The advantage of a high end log splitter is that once it is purchased, the economic pain is behind you if you are healthy enough to do the work. As in most things, one size does not fit all.
This is in perspective of "rural living" where firewood is the main or only source of heat. With only 20 acres, I must purchase logs. I have found what works for me.
Wow. Not many 30" trees in my area that go to firewood. If they are any "good" you might consider selling those for bandsawing into lumber. Should be worth a lot more than firewood. In the 7 years I have been here, I had one tree that size to process. An old maple that was too close to the house and looked iffy. I had a pro come in to take it down and he bucked the base for me as my saw was too small. Wound up using a tractor with tongs to hold sections over the splitter and "chipping" away at it to get it split up. **** stupid way to do it but it got done.
I moved the two largest rounds to the 100 yards range and use them for backstops. I guess they will get "split" eventually.
   / Why I did not upgrade to a better splitter #17
I don't mind burning elm, it's stringy and tough to split and needs a hot fire to catch, but once going it burns well. Like you say, hate to let a dead standing tree go to waste.
   / Why I did not upgrade to a better splitter #18
Listen bucking logs , wrestling rounds , the other work AND a fiancé at 70 ? I'am more impressed by you than the Dyna 14 !
Dang it bless Ya ! Then they call the other guy SuperMan ? IMO the man of steel got nothin on you Don ! :laughing:
If you quit, it's not long until you can't. Use it or lose it.
   / Why I did not upgrade to a better splitter #19
I DID sell the log off the red oak I had to take down year before last, it was 18' long and 30" at the SMALL end, what the mill goes by here. That stump at the cut is almost 46". The one largest limb on that tree was 22" diameter and buried almost 3' into the ground when it was cut off and fell. By the way, I loaded that 18' log onto my carhauler gooseneck with my 40 hp Mahindra and some ingenuity.
   / Why I did not upgrade to a better splitter #20
That was a big log!!! It must have weighed a bit more than your tractor. I'll not try to guess the weight of it this time, I've been corrected too many times. :eek: Yet I'll bet that you knew it was on he trailer when you were going down the road.
Caterpillar Loader Quick Coupler (A56436)
Caterpillar Loader...
2019 F150 (A56438)
2019 F150 (A56438)
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2005 Isuzu NQR 4 door box truck with folding gate (A56436)
2005 Isuzu NQR 4...
