Why I hate ST trailer tires
   / Why I hate ST trailer tires #21
Max pressure on the side of the tire is 40 psi . Checked it when I got back , still had 35 psi .
I have never seen a ST tire less than 50 psi. You sure they were trailer tires?
Chris
   / Why I hate ST trailer tires #22
   / Why I hate ST trailer tires #23
All Load Range "B"... Personally, I would not put Load Range "B" tires on a garden cart, much less a trailer that travels on public roadways.
That 13" only rated for 1100 lbs. Our little 17' Hybrid camper got new bias ply tires this month. 185/80D13 8 ply, 1710 lb @ 65 psi. I think 13" tires are a joke anyway, but put about 500 miles on it two weekends ago. Preformed well.
Agreed on valves stems. Metal valve stems are always a good idea, regardless of PSI.
CT
   / Why I hate ST trailer tires #24
These are not what I call trailer tires, and especially not suitable for the trailer the OP posted. 205/75/13 are the smallest trailer tires I would consider trailer tires and they are few and far between with 205/75/14 being the smallest you see 99% of the time on a trailer like the one pictured.
Chris
   / Why I hate ST trailer tires #25
Chris
Not starting a food fight. But did you mean ST205/75R15? I do not believe any mfg makes a 205/75/13... I believe 185/80/13 is the largest 13" trailer tire manufactured.
CT
   / Why I hate ST trailer tires #26
Not starting a food fight. But did you mean ST205/75R15? I do not believe any mfg makes a 205/75/13... I believe 185/80/13 is the largest 13" trailer tire manufactured. CT
You are correct. I meant 185/80/13.
Chris
   / Why I hate ST trailer tires #27
I enlarged the picture the OP posted.
I have questions...
1) It's a Uniroyal. Are Uniroyal's made in China?
2) Does Uniroyal make a ST tire? Website doesn't list trailer tires.
3) If its a 14"-15" ST tire, why only 35 PSI?
Go back to post #1. View the pictures again. Then re-read this post (#27).
I'm thinking this was not a Chinese ST tire. It was a Uniroyal, load range "C" (Rated at 35 psi) passenger tire on a trailer that failed. Wrong tire for the application. I can be wrong.
CT
   / Why I hate ST trailer tires #28
Uniroyal tiger paws.
   / Why I hate ST trailer tires #29
I enlarged the picture the OP posted. I have questions... 1) It's a Uniroyal. Are Uniroyal's made in China? 2) Does Uniroyal make a ST tire? Website doesn't list trailer tires. 3) If its a 14"-15" ST tire, why only 35 PSI? Go back to post #1. View the pictures again. Then re-read this post (#27). I'm thinking this was not a Chinese ST tire. It was a Uniroyal, load range "C" (Rated at 35 psi) passenger tire on a trailer that failed. Wrong tire for the application. I can be wrong. CT
I have never seen a Uniroyal ST tire.
Chris
   / Why I hate ST trailer tires #30
Michelin owns Uniroyal and (although things change all the time) they don't have much Chinese sourcing. A few years back Uniroyal LTs were recalled because of tread separation problems.
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 20ft...
2014 Dodge Avenger Sedan (A56859)
2014 Dodge Avenger...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56438)
2023 Top Air ATV...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
