Gary Fowler
Super Star Member
- Joined
- Jun 23, 2008
- Messages
- 11,917
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
That is exactly why OA welding is not popular today, cost per inch of weld and of course the intense heat is not really labor friendly either. Labor costs contributed to the development of MIG and FCAW welding as it is more cost effective than stick. Stick when thicknesses and material type permit are more cost effective than OA or TIG. TIG is way more cost effective than OA and regardless of what seabees brother in law said, OA is not faster than TIG. Perhaps in the 60's it could have been as TIG was in it infancy at that point and not many welders knew how to weld with TIG. Mostly it was used in the aircraft industry for welding aluminum and magnesium and didnt enjoy much popularity in steel fabrication till early 70's. Prior to that open butt on alloys that couldnt be welded with 6010 electrodes used what was commonly called a "chill ring" which was a backer ring that was placed inside the pipe prior to fitup. You could then weld the root pass with low hydrogen type rods. As the "new " process of TIG became more accepted and cheaper it became widely used and still is today. MIG and FCAW are still not widely accepted in petroleum and refinery application by design and owners due to the bad rep it got when first introduced. Still today, an incorrectly set machine can cause major weld discontinuties that wont be discovered till xray machines take a look. TIG and Stick continue to be the preferred processes for field work with MIG, FCAW and Subarc welding being confined to shop conditions and roll out applications where defects are less likely to occur.
OA still cant be beat for soldering application in lead and zinc which to my knowledge still can only be welded with oxy-acetylene torch. I myself keep a small #1 welding tip for thin stuff that cant be done with stick which is my preferred process. I love to MIG weld, but I just cant justify the $1000 it would cost me to get a good 220volt machine or even to just add a wire feeder to my Miller CC/CV power pack that I use to stick rod with. If my health enabled me to open up a welding shop then things in my shop would be somewhat different including a high-frequency TIG rig for aluminum, a hand held spool gun for MIG aluminum and a good wire feeder for steel.
As it is now with just fixing a few broken things and small projects, OA and SMAW work for me for all issues.
