Why there's so many homebuilt trailers
   / Why there's so many homebuilt trailers #11
Hmm - - I never thought about registering or titling my homemade trailer (post #3). Its rated at 20,000 lbs and is only used on my property.
Around here those are called "wagons". I think what's being discussed here are trailers you pull down the highway behind a truck. Or in the case of some of these slapped together homemade jobs, behind something like a Ford Tempo.
   / Why there's so many homebuilt trailers #12
I once started to build myself a trailer and began a list of new parts & prices that I needed. I found that they sell new trailers as cheap as I could build one from scratch, but that is buying every nut/bolt, tires, axles and piece of steel new as I did not have any old stuff laying around to make it from. Had I a set of axles or frame available (cheap or free) or a source for wholesale trailer parts, I might still try it one day.
   / Why there's so many homebuilt trailers #13
Over the years I built several trailers, mostly for people who needed something built with certain custom features. All were registered as homemade trailers, since I don't have a business license for building them. One of my first was a 33' car hauler, last time I saw it... it had worn out two diesel pickups, wrecked a couple of times, and looked like heck, but the driver said it had been a good trailer. (I saw it out on the road, just asked about it, didn't tell him that I built it)
David from jax
   / Why there's so many homebuilt trailers #14
I have built several trailers using old gas station car lifts. The long metal lifts are perfect for holding a cab and a half pickup truck. Nice and low when finished. I have one set remaining for some future project. The problem now is gas stations sell gas;and that was the end of my supply of trailer parts.
   / Why there's so many homebuilt trailers #15
I had a homebuilt made out of a Ford Econoline van with the cab part cut off but the frame rails got bent inwards and made up the hitch. That thing pulled like a dream. In order to 'feel' it behind you, you had to look in the mirror.
   / Why there's so many homebuilt trailers #16
I built mine from a trailer my neighbor gave me. It was originally a grape hauler. They load a pair of 2000lb grape bins on it and pull with a tractor. The trailer is only a 4x8 bed, but the frame is made from 2x4" box tubing that is 1/4" thick. The frame would haul my diesel truck, but the tires wouldn't. Its single axle, and he originally had a MH axle on it. I bought a 3500lb axle, with backing plate for brakes, but haven't put brakes on it yet. I added sides and steel loops for tie downs to haul my Massey Furguson 1010.
I also added a tailgate and built ramps to get wheeled vehicles in. I have about $1000 in it and you cannot touch a trailer that capable for $1000 from ANY maker around here. They have 4x8 trailers for about $1500 but they won't take have the loads I have put on this thing. It's hauled two full pallets of used bricks, without a whimper. The only issue when I haul that kind of weight is getting it far enough forward for control. The sides make it hard to push the pallets all the way to the front. Once I had to unload the top three rows from the rear pallet and stack them around the front. That did the trick.
I will build another, a goose neck some day, if the right materials happen my way.
   / Why there's so many homebuilt trailers #17
   / Why there's so many homebuilt trailers #18
20,000 pounds? Good luck towing that with your ATV...
   / Why there's so many homebuilt trailers #19
Thee are a lot more trailers titled as homemade, than there are homemade trailers...
2004 INTERNATIONAL 9400I DAYCAB (A55745)
2004 INTERNATIONAL...
2023 New Holland TS6.140 T4B MFWD Tractor (A53485)
2023 New Holland...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
20ft. Deer Gate (A53424)
20ft. Deer Gate...
PALLET OF MISC TRUCK PARTS (A55745)
PALLET OF MISC...
1839 (A51248)
1839 (A51248)
