Snow Attachments Why use Skid Shoes on Snow Plow ?
   / Why use Skid Shoes on Snow Plow ? #11
George it's hard to see from Jerry's 1st picture so I lightened it up some. The shaft attached to his skid shoes appears to be rectangular instead of a round shaft.
That's correct, it is rectangular. Drilling through the side is a good idea and a bit less work, though not as good, as replacing the whole assemble with a round bar arrangement.
   / Why use Skid Shoes on Snow Plow ? #13
It could be argued that the rectangular system is stronger than the round bar.
What about drilling a large hole (1/2") & making a bolt & cam arrangement for infinite adjustment?
   / Why use Skid Shoes on Snow Plow ? #14
Jerry might also find someone with a CNC Plasma machine, they could very easily cut rectangular spacers from 1/4" or 1/2" plate to use as shims to keep the original arrangement.
   / Why use Skid Shoes on Snow Plow ? #15
</font><font color="blue" class="small">(
I think my biggest problem right now is that the blade works very poorly in reverse. )</font>
You need to make yourself a 'back blade attachement'
Essentially this is a , say, 1/2" X 4" flat plate that is as long as your plow is wide.
It is hinged on the backside of your plow so that when plowing forewards it flips up and simply follows along.
When you plow in reverse it flips down and acts as hook to scrape backwards.
Naturally you need various cut outs to clear the shoes as well as the moldboard ribs (or bows)
In urban areas this is how the contractors get to scrape clean up to the garage doors.They drive up to the door , drop the plow and back up a little more than a truck length then back up to the door drop the plow and push everything out to the street. (and then push all onto your lawn, or get fines)
I also never use skids or shoes.
On gravel drives we plow backwards to compact the first snowfall into the gravel and afterwards simply plow without shoes.
With shoes you only build up a hard packed base bit by bit until you have a real spring thaw mess of bumpy slushy rutty surface that you will be forever hated for.
Most guys simply weld short 1/2 x 2" (4"long) flats on back edge of the long flat backblade to coinside with the ribs or bows of the mouldboard.
Drilling the ribs and flats make for a hinge using appropriate bolts for hinge pins.
Sure you get the idea.
Good luck.
   / Why use Skid Shoes on Snow Plow ? #16
Mike,
When I first read Jerry's post I couldn't view the pic of his shoe. (don't know why, just got a square box with a x in the corner) About half way through my reply I went back and was able to see it thus changing my reply to drill holes through the flat of the rectangle to adjust the height rather than using the predrilled holes he has at the back.
George
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
2003 Lincoln Aviator (A50515)
2003 Lincoln...
KUBOTA SVL97-2 SKID STEER (A51242)
KUBOTA SVL97-2...
New 4-17.5 Forerunner Skidloader Tires (A50774)
New 4-17.5...
2016 Nissan Pathfinder SUV (A50324)
2016 Nissan...
2018 WACKER NEUSON RD28 120 DOUBLE DRUM ROLLER (A51242)
2018 WACKER NEUSON...
