Wide mounted tires>premature bearing failure?
   / Wide mounted tires>premature bearing failure?
It is harder on the bearings, but probably not so bad as to worry about it unless you do heavy loader work on rough ground, at a speed other than very slow. But, doing my usual though experiments (make it much wider, much narrower, much heavier, much lighter, much faster, much slower) I come to the following conclusion:
Unless you can make the front very very wide, and be assured the axle won't simply break, due the to pivot point, a wide front axle will not add appreciably to stability. It will give the perception of increased stability, but it will not help much against a roll over.
The rear axle is key, and wider there is definitely a help, but even so, ballast is still the key.
rear axle is maxed-out, too on width.
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A53472)
Texas Post Driver...
JOHN DEERE 9R640 LOT NUMBER 252 (A53084)
JOHN DEERE 9R640...
City of Buckhannon - Kawasaki 4010 Mule (A52384)
City of Buckhannon...
(APPROX 24) 2" X 3" X 49" THICK TUBING (A51247)
(APPROX 24) 2" X...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
