Rotary Cutter Will a 5' KK rotary cutter fit the JD I-match
   / Will a 5' KK rotary cutter fit the JD I-match #1
gordon21
Lake Lure NC
JD 790
Will a 5\' KK rotary cutter fit the JD I-match
Model L-60-40-P 5' wide 40HP gearbox model
Will it hook up to the CAT 1 JD I-match without any alteration needed?
   / Will a 5' KK rotary cutter fit the JD I-match #2
Re: Will a 5\' KK rotary cutter fit the JD I-match
Depends on the spacing of the lower stubs (pins), and if the top hook can slip under the top link attachment. Also, need to have the accomodation for the free movement of the 'tail' of the cutter. I use a chain on mine. (see attached)
   / Will a 5' KK rotary cutter fit the JD I-match #3
Hmm... chains on your hog? Don't intend to hijack this post -- but did you remove the solid, steel braces from the toplink and replace them with chains? If so, what are the advantages of doing that? Thanks for the response.
(Yah, I'm kinda thinking about a q-tach and a mower.... so, thanks again.) /forums/images/graemlins/wink.gif
30in Forks and Frame Mini Skid Steer Attachment (A55851)
30in Forks and...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
