Tractor Sizing will Ford 451 sickle fit a Kubota L3450?
   / will Ford 451 sickle fit a Kubota L3450? #1
jbetts
I've got a lot of creek bank to mow and can't safely get to it with a 4-foot Haban sickle or rotary cutter. Am thinking of getting something like a Ford 451 seven-foot sickle bar, but don't know if it's a good fit for my 2011 Kubota L3450 tractor. Anyone tried to match those two?
   / will Ford 451 sickle fit a Kubota L3450? #2
I assume by Ford you mean a New Holland 451 (they did have a Ford badge on them for a few years), if so then yes it should work well. However, you will need to get the 'compact tractor adapter kit' from New Holland or fab up something similar yourself. The reason for this kit is that the 3pt hitch arms are too close together on compact tractors which makes the bow frame on the mower hit it. The kit simply extends the frame out for clearance. I have a 451 that I use on my little B3200 and it works well (I made my own adapter)
   / will Ford 451 sickle fit a Kubota L3450? #3
22" is the width of the inverted U on the 450 and 451. Ken Sweet
   / will Ford 451 sickle fit a Kubota L3450? #5
jbetts,
I assume your tractor is a Kubota L3540 if it is a 2011. I have a Kubota L3430 and a New Holland 451 Mower. The mower does not fit for the reasons stated above.
Charleyfarmer,
Tell me more about the adapter you priced. Does it modify the mower or the tractor?
Verticaltrx,
Can you provide a picture of the adapter you made?
OrangeGuy
   / will Ford 451 sickle fit a Kubota L3450? #6
What is the part number for the New Holland 451 compact tractor adapter kit. I have a Kioti DK45SE HST cab.
   / will Ford 451 sickle fit a Kubota L3450? #7
What is the kit number. I need one for my Kioti DK45SE HST Cab.
   / will Ford 451 sickle fit a Kubota L3450? #8
Does anyone have a manual for the 451?
   / will Ford 451 sickle fit a Kubota L3450? #9
One of my sister has it.. I will make it confirm from her.
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2005 John Deere L118 Automatic 42in Riding Mower (A51694)
2005 John Deere...
2014 Ram 4500 Chassis Versalift Bucket Truck (A52377)
2014 Ram 4500...
6" & 12" CHANNEL IRON UP TO 23 1/2' LONG (A51247)
6" & 12" CHANNEL...
UNUSED RAYTREE REDM32-32" EXCAVATOR DRUM MULCHER (A51248)
UNUSED RAYTREE...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
