Will Kubota 5240 third function hydraulics run a sander motor?
   / Will Kubota 5240 third function hydraulics run a sander motor? #11
Yes you can run a constant use hydraulic motor on that system. Heat could be a problem but for the short amount of time you need to run it I feel you are safe. The tractor should give you over 8 gpm on the front. We sell a front hydraulic drive mower off the loader for trees and other uses called the Lane Shark and so far so good!
   / Will Kubota 5240 third function hydraulics run a sander motor? #12
I bought a hydraulic motor driven sickle bar cutter.
Attached to the bucket of my M7040 and run from a rear remote.
The issue I have had is the limited flow and pressure requirements for this hydraulic motor by Danfoss.
500 psi and 5 gpm
I tried controlling the motor speed manually but in the end I bought a pressure compensated flow control.
Winter arrived before I worked out the installation bugs.
Dave
2005 GMC Sierra Pickup Truck, VIN # 2GTEK13T851399344 (A51572)
2005 GMC Sierra...
STORAGE FEES (A53426)
2015 Mack GU813 Mixer Concrete Truck, VIN # 1M2AX13C0FM028499 (A51572)
2015 Mack GU813...
New/Unused Gold Mountain Shelter 20ft x 30ft (A51573)
New/Unused Gold...
Electric Concrete Mixer (A51573)
Electric Concrete...
