Will L3700 lift hay bales?
   / Will L3700 lift hay bales? #11
Thanks. But I'm new to all this. How do you counter weight the FEL?
You can either add weight to the rear wheels by having fluid put in the tires or buying weights that mount inside the rear rim. Another option, that we run, is to put weight on the 3pt hitch. You can do this alot of different ways here are a few, a ballast box, by hanging an attachment (a mower, box scrapper, ect), or a fairly cheap way is to hang a 55gal drum of concrete off the rear. I did the 55 gal drum, we have used this on a few bigger tractors over the years and worked good so I did it with the L3600 also. Granted the 1000+lbs is over kill for a FEL that is "rated" at 1500lbs, but it works very well. In the winter with the big 90" snow bucket the L3600 will have a 82" blower hanging off the rear.
Just a thought - add a rear 3pt bale spear and grab a bail with that - it will easily lift it on the rear and it can be used for rear weight.
there's an idea. I plan to read up on all of it. I was just considering my options. thanks all.
MURRAY 22" 2N1 SELF PROPELLED PUSH LAWN MOWER (A51248)
MURRAY 22" 2N1...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2014 Jeep Compass 4x4 SUV (A51694)
2014 Jeep Compass...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
2010 Ford F350 Super Duty, Super Cab, CM Flatbed (A52384)
2010 Ford F350...
