Loader Will loader mounting brackets off of a JD 2840 fit on a JD 2955?
   / Will loader mounting brackets off of a JD 2840 fit on a JD 2955? #1
Tonker321
Fountain Inn, Sc
Ford 3000
We are looking to put a 148 loader on our 2955. We found one for sale locally with the mounting brackets but they came off of a 2840 and not sure if there is any difference in brackets between the two models.
   / Will loader mounting brackets off of a JD 2840 fit on a JD 2955? #2
Look for more verification, but the brackets should fit and the loader should work if the 2955 is 2WD. A 148 loader won't work on a tractor with MFD due to the loader arms being too low and short.
   / Will loader mounting brackets off of a JD 2840 fit on a JD 2955? #3
Loader brackets on JD 6 cyl engine models need to attach to rear axles to give added support for clutch housing. Yes 2840 brackets will fit 2955.
   / Will loader mounting brackets off of a JD 2840 fit on a JD 2955? #4
where on the frame to i mount the brackets for a farmhand 520 on my JD 2840
   / Will loader mounting brackets off of a JD 2840 fit on a JD 2955? #5
dennisq1
:welcome: to TBN
I'd think that AGCO (who I believe sells the farmhand 520) should have the bracket info available for your JD 2840.
   / Will loader mounting brackets off of a JD 2840 fit on a JD 2955? #7
here's a parts photo for mounting brackets for a JD 148 loader for a 6 cyl JD utility 2WD tractor.
2021 SANY SY365C9C5K (A58214)
2021 SANY...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
BLUE DIAMOND HYD 16" SERIES 2 COLD PLANER (A60429)
BLUE DIAMOND HYD...
14C SCRAPER (A58214)
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A61307)
2023 Kubota...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
