Will Pat's ez change work on cat 2 hitch?
   / Will Pat's ez change work on cat 2 hitch? #11
Re: Will Pat\'s ez change work on cat 2 hitch?
That is correct, specify cat II. I bought a set from Pat's and received cat I. At the time I didn't know any better but they were too small for my cat II lift pins. Pat's did not ask me which ones I wanted so I didn't know there were different ones available. I ended up taking the pivoting lock out and re-grinding the radius on them to make room for my cat II lift pins. Works just fine, although I wish they would have told me or asked me which ones I needed.
   / Will Pat's ez change work on cat 2 hitch? #12
Thanks fellas. I am going to call tomorrow to make sure I get the right ones. This place sure is costing me a bunch of money /forums/images/graemlins/laugh.gif ........all of these neat gadgets. Sure is gonna make life ALOT easier I hope.
   / Will Pat's ez change work on cat 2 hitch? #15
I have a set of Cat II attachments. TBN only sells Cat I attachments. As I understand it, if you want anything else, you need to order directly from Pat. I did and have been fully satisfied.
   / Will Pat's ez change work on cat 2 hitch? #16
I just got it ordered. Thanks again!
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A51246)
2020 CATERPILLAR...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2013 Dodge Charger Sedan (A51694)
2013 Dodge Charger...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
