MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 58,182
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Re: Will PT 60\" Blade remove snow for business?
Well, a parking lot is a lot different than a driveway or sidewalks at a mall/shopping center. I've had a pickup mounted plow and I have a PT425 with a plow. In a driveway or sidewalk situation, or close to buildings, the PT425 will run circles around a pickup truck all day long. It is quicker to turn around, easier to navigate with, the plow is smaller and can get into tighter places and it can pile higher, narrower piles(plus you can pop on the bucket for deep stuff like drifts between buildings and under covered walkways, etc...). However, from my experience plowing the tarmac at airports, out in an open parking lot with no obstructions, any pickup truck worth its weight will run over the PT425. It can go much faster with a bigger blade and can go through deeper stuff just because of its weight and horspower. It can also pile high, but the piles und up being wide. The height comes from bashing the piles at the botton, forcing stuff up, whereas with the PT, you can tip the blade back as you lift, pushing the snow higher without bashing the pile. Easier on the machine and your guts.
So, I'd say it depends on the shape of the parking lot. If it is long and narrow, the PT might do OK. If you have lots of sidewalks that a pickup won't fit on, the PT will be super. If you have driveways, the PT will be outstanding. But if you have a large, square parking lot the pickup would be my choice.
As for adapting a pickup plow to a PT425, the adapter plate is $100.00. The fittings and hoses to adapt it will probably be another $100. I don't know if the angle cylinders on the pickup plow are single or double actings, so I don't know how to plumb it. Anyway, you'd have $200 in it and it might be too heavy for the PT425 to lift well. The new PT plow is under $500.00 isn't it? Might be better off going with factory in this case.
Hope this helps and just my opinions. /forums/images/graemlins/laugh.gif
